2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine swap
Old Feb 28, 2016 | 11:27 PM
Jrocky's Avatar
Post Engine swap
Hi, i have a 09 lap engine cobalt automatic and it been in a accident. The engine in it still has 60,000 miles and i was wondering what other car would go perfect with the swap? There a few pictures of the balt you can view... and is there any advice about what i shouldnt do, any tips would be helpful
Attached Thumbnails 1446547603738_resized.jpg   1446547604816_resized.jpg   1446547605629_resized.jpg
Old Feb 29, 2016 | 12:02 AM
06_ion2's Avatar
Scrap it and start over. It's not that easy to swap these into other things.
Old Feb 29, 2016 | 12:48 AM
Jrocky's Avatar
what if i swap it with another cobalt ?
Old Feb 29, 2016 | 02:14 AM
Jrocky's Avatar
I got all the time in the world, so id like to know what needs to be done to swap the lap engine in L61 engine
Old Feb 29, 2016 | 09:19 AM
06_ion2's Avatar
The head and motor harness is different depending on what year l61.
Old Feb 29, 2016 | 12:41 PM
Jrocky's Avatar
Lets say a 07, like if i took the engine out of the L61 car and then took the Lap engine out of the other one, what things would i have to change in the car?
Old Feb 29, 2016 | 04:16 PM
Jrocky's Avatar
or do you think i should buy a cobalt and take everything out of it and put everything in my cobalt in that. I'm talking about rewiring it
Old Mar 1, 2016 | 12:23 PM
ItalianJoe1's Avatar
You'd have to swap the entire harness/PCM, then try to get it to play nice with the BCM and the rest of the network. It's possible, but not worth it IMO for a base model auto car. In good shape the car is only worth a couple grand, so you're gonna buy a broken one, then spend hundreds of hours swapping everything, to end up with another base model car?
Old Mar 1, 2016 | 12:42 PM
whats wrong with having a base model car?
OP its pretty easy to do in an 07+ l61 car if you have hptuners
i have an l61 car, swapped in an 07 le5, used a 10 lap engine harness, and am running an 08 LE5 tune on the stock ecu.
anything is possible
Old Mar 1, 2016 | 01:06 PM
Value/time issue, nothing wrong with the car itself. If you value your labor hours at zero then anything is worth doing. Personal choice.
Old Mar 1, 2016 | 01:59 PM
Says the guy with a turbo toyota tercel
I get what you mean though. Depends on what you wanna do with it.
Old Mar 1, 2016 | 04:18 PM
Jrocky's Avatar
All the hours im going to be putting into this is nothing for me atm, I'm currently on EI atm so i got plenty of time until i goes back to work. Me and my father would be worth on this together so he'd will give me a hand with all of it. lets say i bought this car Cobalt for parts $400 ono | used cars & trucks | St. John's | Kijiji and i took everything out of the lap and put it into this white cobalt, like i mean everything the guts and all, would it be possible?
Old Mar 1, 2016 | 04:20 PM
yes its possible
Old Mar 1, 2016 | 04:21 PM
Jrocky's Avatar
or maybe this car? 2005 cobalt | used cars & trucks | St. John's | Kijiji
Old Mar 1, 2016 | 04:25 PM
Jrocky's Avatar
yea im just going to gut both cars and take everything from the lap and put it into the other one?
Old Mar 1, 2016 | 07:11 PM
Bought that car already swapped and boosted, for 2K, and it's faster than a bolted LSJ. I don't see the problem there.
Old Mar 1, 2016 | 07:41 PM
06_ion2's Avatar
To turbo a lsj it's just a few bolts also.
Old Mar 1, 2016 | 07:46 PM
T-fog's Avatar
Yes sir, Harnesses, computers and all.
Old Mar 1, 2016 | 07:52 PM
Jrocky's Avatar
Great, can't wait to start this project. I'm going to be starting at the end of march, ill keep posting picture of the build.
Old Mar 1, 2016 | 08:12 PM
thats not really necessary...
I left all of my internal body wiring alone. There are a couple connectors you have to repin but thats not hard at all. All 07-10 base models use the same ecu. Since you already have the ecu you need, you would probably only need to do a VATS(vehicle antitheft system) delete and the car would start right up.
Old Mar 1, 2016 | 08:39 PM
Jrocky's Avatar
So your saying all i would have to do is take the engine out and put the other engine in, switch ECU's and hook up all the harness's and deleted the VATS and it would start?
Old Mar 1, 2016 | 11:36 PM
Ok you win, the cobalt is the best car ever.
Old Mar 1, 2016 | 11:37 PM
Theoretically, yes because it's the same ECU and basic setup.
Old Mar 2, 2016 | 01:01 AM
Yes, that exactly what i did.
There is one connector that goes between the two big ecu connectors and that will have to be repinned, but its pretty simple. once you get there i can get you the diagrams
Old Mar 2, 2016 | 03:01 PM
Jrocky's Avatar
Could you get me the diagrams now for future purposes and what about the vvt on the lap, do i just got to hook up the extra harness and put it the ecu?
