Gene's 2.2 LAP Supercharger Build
Ok, so I ordered another ZZP triple gauge pod and I got the correct Interceptor today. If I have time this weekend and I get all of my stuff together maybe I'll wire up the Interceptor. I want to know how much HP it has stock.
How much coolant will be needed? I was talking to Gene over the phone, and he pointed out that I probably won't lose that much from the engine, if I'm careful.
How much will the heat exchanger circuit hold?
I'm looking at something like this as a reservoir: http://shop.oreillyauto.com/ProductD...egoryCode=3052
I can walk to the store in 5 minutes, and I have my parents cars, Maybe I'll grab one for each - the engine and the HE circuit, and go from there. Water Wetter in both? I'm gonna run 50/50 in the H/E cause it gets nipply here in the winter.
I just filled the system through the reservoir as much as possible, ran car for 30 sec, shut off car, refilled reservoir, and repeated until coolant was continuously flowing through the reservoir. Did this 5 or 6 times , then kept a bottle of coolant in my car for the next day or two as it was obviously still bleeding air out cause I had to refill the reservoir a few more times. I'm sure i could have used the bleeder screw on the top of the stock h/e to speed up the process, but oh well. Oh and the zzp h/e was NOT a direct fit on my 2.4without grinding some material to get the tabs to reach the bolts behind the crash bar.
One of the how to's said to tie it in with your fuel pump fuse. If fuel pump is on and running you need the IC pump.
The bolts are the hex socket type ... and they are much, much longer as they go through the SC, into the intake and then pretty far down into the intake manifold.
I would say they are at least 50 MM.
Last edited by Gene Culley; Jun 11, 2009 at 07:20 PM. Reason: Automerged Doublepost
http://www.ecotecforum.com/forums/sh...49&postcount=3
ahhh actually my bad...I mixed up the last 2 numbers of the p/n lol...anyway. thanks for the real size.
Doesn't have to be a hex bolt...I used
M8x1.25mm double sided stud x2
M8x1.25mm 55mm flared bolt x2
M8x1.25mm flared nuts x2
Works fine, and are easily found at Autozone or other parts stores
I thought that was oddly small but thats all I could find.
I understand. I'm pretty much a factory type guy and I wanted them to be the same as factory.
Last edited by Gene Culley; Jun 12, 2009 at 08:21 PM. Reason: Automerged Doublepost
