2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
intake installed
Old May 1, 2013 | 11:38 PM
owlwyn's Avatar
intake installed
so the intake I ordered came today, and got installed. and... I'm fairly impressed with it. I can definitely notice a better throttle response, and I love the sound it makes at the high rpms. I feel like a kid on Christmas. haha.
Posted from Cobaltss.net App for Android
Old May 1, 2013 | 11:41 PM
YelloEye's Avatar
When you get PE delay turned off it's a huge difference in throttle response.
Old May 2, 2013 | 12:01 AM
2010CobaltLTfan's Avatar
What's the pe delay and how will you get it removed I'm guessing by tune right
Old May 2, 2013 | 12:10 AM
owlwyn's Avatar
wondering the same. never heard of PE delay before
Old May 2, 2013 | 12:13 AM
I would like to know what it is so I can remove mine lol
Old May 2, 2013 | 12:26 AM
BankerBalt's Avatar
power enrichment delay. stock it delays until a certain rpm i believe
Old May 2, 2013 | 12:30 AM
owlwyn's Avatar
oh boo. sounds stupid. -.-
Old May 2, 2013 | 12:34 AM
So you have to get a tune to remove it
Old May 2, 2013 | 01:39 AM
Jesse's Avatar
PE Delay really has nothing to do with throttle response in the 2.2L. It's the throttle opening rate. Stock opening rate is 1-8% ramp rate. I've got my opening rate 100% and PE Delay still on and I can spin the tires in place with no brake. Impossible with the stock opening rate.
Old May 2, 2013 | 07:09 AM
owlwyn's Avatar
oh ok, still need a tune to change it I'm assuming
Old May 2, 2013 | 03:35 PM
Jesse's Avatar
Yep, but hopefully your tuner when you eventually get one will already know about all that.
Old May 2, 2013 | 03:45 PM
Terminator2's Avatar
What is the PE delay RPM and enrichment rate stock? Some of the GM trucks had a 4800 RPM PE delay which caused huge power losses at WOT below 4800.
Old May 2, 2013 | 05:24 PM
Jesse's Avatar
Old May 2, 2013 | 05:35 PM
owlwyn's Avatar
IMAGE#1
that seems a bit high, I don't even reach 8k.. well its not like I could even if I wanted too.
Old May 2, 2013 | 07:32 PM
YelloEye's Avatar
Interesting, I had always understood PE Delay as being a time thing, ex: .XX sec after WOT, the car actually pulls the TB open to WOT. I know my 2.2 felt laggy as hell before tune, after with PE delay gone and a few other adjustments the pedal felt like it was actually attached to the butterfly.
Old May 3, 2013 | 01:35 PM
Jesse's Avatar
PE is simply adding more fuel to the engine, nothing to do with the throttle body. That's where the opening rate comes in. Stock, it only opens at a rate of 8%. That's not the max it can open, but rather the rate at which it opens. I have my PE Delay set to 5000rpm, but I'm getting KR at 80mph WOT at 4200-4800rpm. I'm tempted to lower it to 3000-3500rpm. Did you do your own tune or did someone else do it? If you have HPT it'd be worth taking a gander at the opening rate table.
Old May 3, 2013 | 01:43 PM
YelloEye's Avatar
No, this was on my 06 2.2, Vince at Trifecta did mine at a buddy's garage nearby.
Old May 3, 2013 | 01:50 PM
Jesse's Avatar
Fair enough, HP can't tune those haha. But chances are high that he modded those tables and that's why it got better throttle response.
Old May 4, 2013 | 11:31 AM
That would make it seem that the car never enters PE unless you reach 8000 RPMs. Strange.
Old May 4, 2013 | 08:06 PM
Jesse's Avatar
I have two valuable, interesting bits of info to post here. First is a vid I found in another thread and section of this forum. It's a vid of a Trailblazer throttle body with and without a tune for the throttle opening rate. The opening rate is even higher on the Trailblazer than the Cobalt 2.2/2.4 by a good bit, if the info from the vid is correct.
My other bit of info is this: I set my PE delay to 3000rpm and noticed something interesting. While datalogging before messing with the PE, I noticed a considerable KR at .46-.54G/Sec and 3600-4800RPM at various speeds. Around 80mph WOT in 3rd gear, I noticed 4* of knock for several seconds. After setting the PE delay to 3000rpm, I experience no KR whatsoever on a 0-110mph run at WOT, except for maybe .5* KR when shifting into third.
Old May 5, 2013 | 08:50 PM
owlwyn's Avatar
ill be honest, I have no idea what you guys mean by KR..
Old May 5, 2013 | 09:02 PM
Jesse's Avatar
Knock Retard.
Old May 5, 2013 | 09:49 PM
owlwyn's Avatar
Quote:
Knock Retard.
ahh. ok.
Old May 22, 2013 | 10:12 AM
cobaltune's Avatar
wrong my buddy can burn out in his g5 like nobodys buisness WITH NO BRAKE
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Sep 25, 2015 06:06 PM
