2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
M62 Install on 2.2LAP (XFE Remix)
Old 06-27-2010, 02:47 PM
  #51
MP81's Avatar
You don't repin anything - you just wire the 8-wire pigtail to the 6-wire harness.
8 Pin
Pin A (Dark Green): TP Sensor 1 Signal
Pin B (Light Blue/Black): 5-Volt Ref 2
Pin C (Black): Low Reference
Pin D (Purple): TP Sensor 2 Signal
Pin E (Yellow): TAC Motor control 1
Pin F (Brown): TAC Motor control 2
Pin G (Gray): 5-Volt Ref 1
Pin H (Black/White): Low Reference
6-Pin
Pin A (Brown): TAC Motor control 2
Pin B (Yellow): TAC Motor control 1
Pin C (Tan): Low Reference
Pin D (Dark Green): TP Sensor 1 Signal
Pin E (Gray): 5-Volt Reference
Pin F (Purple): TP Sensor 2 Signal
8-Pin >>> 6 Pin
A > D (Dark Green)
B > E (Gray)
C > C (Tan)
D > F (Purple)
E > B (Yellow)
F > A (Brown)
G > E (Gray)
H > C (Tan)
B/G both go to Pin E (Gray)
C/H both go to Pin C (Tan)
I think those colors are still the same (this was for my L61)
Old 06-28-2010, 12:52 AM
  #52
BlackCobalt09's Avatar
Talking
Thank you so much. This is the only part of my build that I couldn't figure out. That might be kinda sad but I usually don't like cutting and splicing till I get someone who knows what their doings opinion. Thanks for the wire reference guide to I will really need that.
Old 06-28-2010, 10:36 PM
  #53
MP81's Avatar
Not a problem, glad to help!
Old 06-29-2010, 12:41 AM
  #54
Pedobear's Avatar
what exhaust set up you going with
Old 06-29-2010, 05:07 AM
  #55
I tried wiring the connectors together yesterday. Well i got them together and all, it started but it didn't run right at all. It idles real real rough. it will take the throttle ok but will not run right. And if it does stall or i shut it off it gives me trouble codes. 6 i think. 3 or 4 of them are just like gene's codes on his car, manifold absolute pressure , the secondary air injection and a few others. i can't remeber i just got off work. But should i take the secondary air off. and something else i have the zzpsupercharger kit and the manifold doesn'e have a MAP sensor on in what exactly can or should i do with it because i'm sure it needs to be hooked up. Thanks.
Not sure about the exhaust yet. gonna have a custom one made a buddy of mine does it. A custom 3 in is what i'm thinking about. ill worry about that once my car hopefully runs sometime soon.
Last edited by BlackCobalt09; 06-29-2010 at 05:07 AM. Reason: Automerged Doublepost
Old 06-29-2010, 06:52 AM
  #56
Cobaltxfe09's Avatar
For now, the LSJ header/downpipe with a custom 2.5" from the flange back.
Old 06-29-2010, 08:35 AM
  #57
roderick's Avatar
Hey cobalt I am going turbo so I have alot of them parts you need. I will sell you the tvs + intake mani + alternator + belt + intercooler and pump with brakets + dual pass + heat exchanger for 2200 + shipping
Old 06-29-2010, 05:47 PM
  #58
No thanks, I don't have "TVS" money. But GLWS!
If you part out, I would be interested in the IC pump bracket. Thanks.
Old 06-29-2010, 07:02 PM
  #59
Pedobear's Avatar
lulz we would blow our motor on a tvs
Old 06-29-2010, 10:59 PM
  #60
MP81's Avatar
True that!
Now throw in some forged rods and pistons and go at it!
Old 07-01-2010, 05:58 PM
  #61
rossshady120's Avatar
i thought you were loving the tvs?
Old 07-01-2010, 07:57 PM
  #62
Pedobear's Avatar
rods and stuff are after i get my 3.0 running on my car then dropping to 2.8
Old 07-03-2010, 04:43 AM
  #63
Just ordered the last of the "oddball" bolts.
Ordered:
-M6 x 1.0 X 75 (Qty 2)
-M8 X 1.25 X 130 (Qty 3)
-M8 x 1.25 x 35
Old 07-08-2010, 05:45 PM
  #64
mongorat427's Avatar
The dealer is fixing my trans with the parts I found. I hope I get it back soon. I got a set of R1 Concepts rotors I want to put on it and am ready to cruise.
Old 07-08-2010, 05:48 PM
  #65
Nice!
Today I recieved the rest of the non-gm bolts from Boltdepot.com
Old 04-02-2011, 05:13 PM
  #66
redcobalt07's Avatar
I miss this build.
Old 04-02-2011, 05:21 PM
  #67
shawn672's Avatar
I miss this build.
I'm guessing it never happened, much like most of the 2.2 builds
Old 02-06-2014, 03:21 AM
  #68
Crav3's Avatar
I really wanted to see this so I coulsbsee how he did the maf sensor lol
dennis69
10-20-2015 07:39 AM
justinchinn
10-02-2015 12:18 PM
Delta coupe
09-30-2015 08:11 AM
goaliemo
09-28-2015 01:37 PM
Bohb
09-27-2015 09:11 PM
Quick Reply: M62 Install on 2.2LAP (XFE Remix)
