2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
standard transmission fluid?
Old May 5, 2010 | 02:33 PM
Schneids's Avatar
went to local parts dealer and they tell me that it gives them a gm code and tells me that i might have to go there to get the fluid?
any help
Old May 5, 2010 | 02:35 PM
hatrickstu's Avatar
get it from GM.
Old May 6, 2010 | 12:01 AM
09blackonblack's Avatar
like $15 for 2 quarts from gm. it takes 1.7 qts. and the drain plug is a bitch to get out. o and use a really long skinny funnel... i used a really long hose attached to a nipple lid from a gear oil bottle... took over 2 hours to fill it using it like an I.V.
and autozone told me it takes 6 quarts lol
Last edited by 09blackonblack; May 6, 2010 at 12:01 AM. Reason: Automerged Doublepost
Old May 6, 2010 | 10:00 AM
xxxxsh4d0wxxxx's Avatar
I believe the LAP also has the F23 trans, same as the L61, and it definitely takes ATF. Not GL.
Old May 6, 2010 | 12:30 PM
it takes dex 6 only available at the dealer
Old May 7, 2010 | 10:08 AM
DEX 6 (VI) ATF though.. NOT GL. And they have DEX 6 readily available on the internet, and most shops around my area, not just the dealer.
Old May 7, 2010 | 11:04 AM
i searched every store here and i could only get it at the gM dealer
but yes it is atf. i changed mine at 50k miles and it was brown and burnt.
Last edited by 09blackonblack; May 7, 2010 at 11:04 AM. Reason: Automerged Doublepost
Old May 7, 2010 | 11:53 AM
Some guy used GL, a while back, I read about it.. It was
Old May 7, 2010 | 06:49 PM
nhanson's Avatar
are you putting AUTOMATIC TRANS FLUID (ATF) in a manual transmission?
Old May 7, 2010 | 06:56 PM
damn skippy i am... it comes from the factory with atf... just like my t56 does as well. and GL? as in gear lube? 90 weight?
Old May 7, 2010 | 10:19 PM
Yes, the F23 takes ATF.
RaginChopsuey
Oct 27, 2015 01:27 PM
Adecker
Oct 20, 2015 09:46 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
