2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Tranny Swap Question
Old Mar 5, 2012 | 03:16 AM
LtDanBoostdG5GT's Avatar
I have a 2009 Pontiac G5 GT, Turbocharged By ZZP
I currently have the Automatic transmission for my car..
But I plan to change it over to manual...
I just wanted to know if anyone knew what trans I should put into it?
Old Mar 5, 2012 | 07:17 AM
07cobaltguy's Avatar
Yeah none. I dont think you understand the magnitude of what you are trying to do. No ones done it, its cost and difficulty are not worth it.
Old Mar 5, 2012 | 07:27 AM
ItalianJoe1's Avatar
You need the F23 manual from the other 2.2/2.4 cars. Along with all the hardware, you may also need to change the engine harness and computers, along with possibly the body harness and computer. Good luck. Why not just keep the auto?
Old Mar 5, 2012 | 07:30 AM
Mr.Tozzi's Avatar
It would probably be cheaper and less work to build the auto, and it also handles more torque than the f23.
Old Mar 6, 2012 | 12:45 PM
bluebalt07's Avatar
You'd be better off buying a car with a manual and swapping the turbo kit over. That would probably be cheaper than buying everything you need to convert to manual
Old Mar 7, 2012 | 02:01 AM
Validater's Avatar
I'm swapping in a F35 and all other parts pretty soon, I'm well aware of all the things that need to be changed. I say its your money and time and your car. Just stick to it and don't give up or you'll just waste your time if you change your mind half way through.
I'm doing it mainly cause I can and so I can supercharge my car and make it stick, And then I have a LSJ lying around that I can build up with a turbo kit from ZZP.
And because the wrecker is letting me take the LSJ full motor assembly for 1000 and trans with LSD for 300. Car is a side impact I believe.
Old Mar 7, 2012 | 02:07 AM
Dontstoprunning's Avatar
sell parts, buy IPT built tranny
Old May 16, 2012 | 05:55 PM
Tundraboarder666's Avatar
Don't buy IPT tranny mine failed first time I went WOT
Old May 21, 2012 | 02:20 AM
Thanks Guys... I ended up pulling out my tranny and had it built up by ZZP... It Is A Charm Let me tell you
Old May 21, 2012 | 09:16 PM
how much WHP/WTQ?
Old May 22, 2012 | 02:59 AM
No Idea didn't dyno... not one close enough too me. I just got a tune and boom... I never really push her to limit anyways... I have a high enough premium haha
brandon04
Oct 21, 2015 07:04 AM
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
