2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
tune up
Old Apr 16, 2013 | 08:31 PM
owlwyn's Avatar
tune up
so I was planning on do the first tune up on my car since I got it, I've had it about a year, and probably the first one its ever had. it has just shy of 75k miles. I'm trying to figure out what I can do, aside from spark plugs and check my air filter, what else can I do? one of the mechanics at my work said my plugs are good for at least 100k but there shouldn't be anything wrong with replacing them now.
so feel free to let me know whether I should just save my money and wait till 100k. or if you have other things I should check or replace.
Posted from Cobaltss.net App for Android
Old Apr 16, 2013 | 08:55 PM
footballplaya3k's Avatar
Oil and filter (obviously), tranny fluid and filter if your auto (can't tell from my phone), fuel filter, sea foam if you're feeling adventurous and plan to change the plugs too, cabin air filter,
Old Apr 16, 2013 | 09:03 PM
owlwyn's Avatar
just did oil and oil change 2k ago and got synthetic in her now, and I have manual trans.
what exactly is sea foam, and what's it do?
Old Apr 16, 2013 | 10:21 PM
nhanson's Avatar
Seafoam is a cleaner. Take you brake booster line off and suck about a 3rd of the can into it (might need 2nd person to keep car alive). Let car sit for 10 min and restart and rev it out till smoke disappears.
Dump rest of can into gas tank.
Old Apr 17, 2013 | 01:34 AM
andrewcarr1993's Avatar
I used two bottles of seafoam in my 2009 LS XFE. One in a full tank of gas. Half straight into the engine and another half into the oil (have to replace it soon after) I run royal purple and the K&N oil filters.
When I did it I had a friend hold the engine at 2k and slowly poured it in and at the end try to pour it in fast enough that you kill the engine, if not make sure your friend knows to shut it off and then let it sit. I didn't replace anything after (spark plugs or O2) but my car only has 52k on it and it only smoked bad for about a minute after I restarted it.
One other thing you can do it replace the cabin air filter, it's behind the glove box.
https://www.cobaltss.net/forums/prob...filter-198527/
Old Apr 21, 2013 | 08:44 PM
owlwyn's Avatar
I changed my cabin air filter the other day. and when I pulled it out it was black, and I thick coat of grim on it. and a lot of bugs stuck to it too. surprisingly no stink bugs tho.
*and had a thick coat
wasn't paying attention when I was typing.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
