2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
vvt cams
Old Dec 29, 2012 | 09:51 AM
Mr.09cobalt's Avatar
Traction conrtrol turns on at 30mph?
i just had my axels check at the dealership[ and now that i got my car back when i turn my car on and drive it up to 30mph the transction conrol turns on at 30mph? anyone have any ideas
Old Jan 29, 2013 | 10:09 PM
rcarr0327's Avatar
im stock now so idk why i care but i guess it would be a good break through for LAP guys. Maybe i would try and go NA if cams were available.
i think they would work, when i was shopping around for a new head some of the part numbers between 2.2 vvt heads and 2.4 vvt heads matched up. not sure about specs on the 2.4 cams though
Old Jan 29, 2013 | 11:05 PM
nhanson's Avatar
You can gain a little bit if you modify VVT. I picked up air flow when I was NA.
Havent tried with changing for the S/C. I reverted back to stock settings when I put it on.
Old Mar 24, 2013 | 02:39 AM
Crav3's Avatar
Anything new on lap cams? Or le5 cams work for lap?
Old Mar 24, 2013 | 08:53 PM
rcarr0327's Avatar
i dont think anyone tried or really is trying. Im not really "cam savvy" but i think that they would work. i know the heads between 2.2 and 2.4s are the same. but the cams and clearance between piston and valves im not sure
like i said in another post. if you put the cams in and try and turn it over by hand and it gets stuck, check timing and if timing is right then we know they wont work.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
