06-07 LE5 engine swap
Old Jan 17, 2015 | 03:04 PM
sheape's Avatar
Not Work Safe 06-07 LE5 engine swap
So i have been posting all over the fourm collecting info on the swap and the build thank you to everyone that has answered my questions
06-07 LE5 Swap
  • 06-07 LE5
  • M62 S/C
  • 2.8" pulley (Sorry i didnt mean 2.6")
  • 2.5" Exhuast
  • K&N fender air intake
  • #60 injectors
  • 60shot of Nitros
  • Stage 2 clutch
  • ZZP Dual pass
  • Dyno Tune
Does this build look okay? Am i missing anything? Rough est on HP?
During the making of this build i will be taking lots of pictures so i can post it up! Thanks for all the help
Old Jan 17, 2015 | 05:01 PM
Spawne32's Avatar
the lowest pulley you can run without having to machine the supercharger for it to fit is a 2.8" pulley, you will also have to have every supporting mod for intercooling otherwise your IAT2's will be through the roof.
Old Jan 17, 2015 | 05:13 PM
blueLNFftw's Avatar
False.
The 2.7" made by smothflow clears stock m62 snouts. I had one.
Old Jan 17, 2015 | 05:49 PM
Spawne32's Avatar
Originally Posted by blueLNFftw
False.
Well that's great...but he wants to run a 2.6" lol
Old Jan 17, 2015 | 08:10 PM
sheape's Avatar
I was mistaken when i typed that i ment 2.8"
Old Jan 17, 2015 | 09:25 PM
Spawne32's Avatar
2.8" is a good pulley to stay with IMO, thats the one I'm using. I believe 2.8" takes the blower the recommended maximum RPM for the M62 from eaton. Which I think is just around 15,000rpm. You still need adequite cooling mods though spinning the blower that fast.
Old Jan 17, 2015 | 09:59 PM
Jesse's Avatar
Will the stock LE5 take all that AND a shot of nitrous? I know 06-07 are forged but I wouldn't put that much faith in them. Nitrous is BRUTAL on bottom ends.
Old Jan 17, 2015 | 10:29 PM
Spawne32's Avatar
One thing i have learned about nitrous, is its all about how you use it and how you tune it. If your constantly blasting dry shots off the line from 7k, I wouldnt be expecting much out of a stock block. But a well tuned wet shot, direct port preferably, from a 2nd or 3rd gear pull should be just as smooth as running more boost.
You could say that the weak spot is the pistons on the LE5 as they are not forged, but I have never had an issue with T6 heat treated cast pistons with ring lands as thick as they are on the LE5 have a problem with anything under 400hp, and from all that ive researched and read over the years, the rods should be just as capable, along with the crank, as the LSJ is in its stock form. Tuning is really the key to longevity.
Old Jan 18, 2015 | 12:29 PM
nhanson's Avatar
Said this before: I was 2.6 pulley and E85 all last year (super fun car)
This year is 2.6 pulley and E85, ported head with 82# valve springs and 75 wet shot (pre blower)
Goal is 400whp with that setup
Old Jan 18, 2015 | 12:35 PM
Wert842's Avatar
Why is this NWS?
Old Jan 18, 2015 | 12:40 PM
Xmetalhead2003X's Avatar
I was just about to ask that too ^
Old Jan 18, 2015 | 01:22 PM
Spawne32's Avatar
Originally Posted by Wert842
Why is this NWS?
very sexy build thread i guess
Old Jan 18, 2015 | 02:52 PM
nhanson's Avatar
Heads fer days...dirty is stock, clean is ported and valve springs
Up close!
Old Jan 20, 2015 | 12:06 AM
Verbatim's Avatar
Im dailying my stock 06 LE5(head studs, ported head)
2.6 tvs; 24gph meth
will be dropping the meth to 7-10gph and making the e85 jump...I was toe to toe with a bolt ons, tuned, e47 LNF at 25psi this weekend...cant have none of that; we were both NLSing by the way
And we bringing that torque thru the roof with some fun VVT tables
Get badass flow thru coolant reservoir, dual pass(eliminate the T fitting and have 2 hoses go to reservoir), phenolic, meth, griffen HE
Old Jan 20, 2015 | 12:15 AM
nhanson's Avatar
2.6 tvs; 24gph meth
Im interested in those VVT tables!
Old Jan 20, 2015 | 12:24 AM
Spawne32's Avatar
2.6 tvs; 24gph meth
also curious about what youve done with the VVT tables
Verbatim's Avatar
its based off of salvo's tables
Just need to get time with ryan(p&p) at the dyno and play around and see what she likes
Old Jan 20, 2015 | 12:57 AM
Spawne32's Avatar
if you can, please share the tables lol im at a bit of a loss as to which direction to go with the VVT once the supercharger is on
Old Jan 21, 2015 | 07:23 PM
nhanson's Avatar
Ive never changed mine...so im assuming theres power on the table still
Old Jan 23, 2015 | 02:09 PM
CudaJoe's Avatar
Wheres the NWS? I am very dissappointed.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
