2.4 build
They were new injectors, 60's when I got the zzp kit. Speaking of that is there anyway to test injectors? Do you think mine are bad with all the metal shavings/chunks flying around in there?
I think I had a coolant leak that lead to this issue. On a better note I just picked up a motor and ordered rods,pistons,valve springs,head studs, and etc. to build it. Should be up and running hopefully within two weeks. Just sucks because I'm not sure if I can make it to the Ohio meet now.
