2.4 Ecu ?
Old Mar 10, 2008 | 10:46 PM
2.4MANX's Avatar
2.4 Ecu ?
I'm using a 2.4 ecotec in a sand rail and need to know if the ECU can be programmed to bypass the drive by wire? If not I'm trying to find out what generation Ecotec does not have drive by wire and if that ECU can be Flashed and reprogrammed to work on the 2.4 ecotech. Thanks
Old Mar 11, 2008 | 11:01 AM
Evil C's Avatar
Are you pod racing?
Old Mar 11, 2008 | 11:36 AM
pajinki's Avatar
As far as I know, all the ecotecs use drive by wire. You might look at the caviliers with the 2.2 ecotecs but as far as the 2.4 goes... They use drive by wire.
Old Mar 11, 2008 | 10:11 PM
vidio1's Avatar
You could contact ATVRacing. They run an Ecotec in one of their sand cars, they might have some info they would share.
http://atvracing1.com/tazcar.htm
Another option is detailed in GM's build book, around page 76.
http://tunersource.gmblogs.com/Racer...mplete-web.pdf
Hope these help, good luck............
Old Mar 11, 2008 | 10:13 PM
Red2.4SS's Avatar
ALL 2.4L Ecotecs use drive by wire.
If you use on older ECM you will not be able to use it on the 2.4L as there have been some changes in the ingition system and VVT has been added.
Old Mar 12, 2008 | 10:20 PM
2.4MANX's Avatar
No. It's actually for a manx style dune buggy.
Old Mar 12, 2008 | 10:23 PM
KyleMinnis's Avatar
wow thats cool...!
Old Mar 13, 2008 | 12:07 AM
2.4MANX's Avatar
Here's a pic of what the 2.4 is going in.
Old Mar 13, 2008 | 12:10 AM
Red2.4SS's Avatar
You may be able to keep the drive by wire if you get the gas pedal assembly as well?
Old Mar 13, 2008 | 12:36 AM
2.4MANX's Avatar
That's what i think i'm gonna result to. I need to figure out what to do as far as the harness off the pedal.
red9
Oct 4, 2017 02:23 AM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
