2.4l turbo manifold
Old Jan 27, 2006 | 10:01 AM
YellowLT's Avatar
Talking 2.4l turbo manifold
Ok so if some of you 2.4 liter guys whining your car is slow, heres a part so you can put your own turbo on. I know it's not a kit but it's a start
http://www.jtuners.com/product_info....c53206e5daeb41
Old Jan 27, 2006 | 10:06 AM
celicacobalt's Avatar
im pretty sure thats for the z24...
Old Jan 27, 2006 | 10:10 AM
Deaf_Dog's Avatar
yeah, i don't think that's for the 2.4L Ecotec
Old Jan 27, 2006 | 02:10 PM
Brandon97Z's Avatar
2.2l turbo manifolds should actually work on the 2.4l
Old Jan 27, 2006 | 02:18 PM
RedBaseBolt's Avatar
Technically speaking the only things that might not be compatible in a 2.2L Turbo kit to the 2.4L is the ECU programming if there is any or shifts points if the trannys are auto. But other than having a slightly bigger bore, the 2.4 is pretty much the same engine.
Old Jan 27, 2006 | 02:43 PM
well what is a good 2.2 manifold that i could use?
Supercharged06SS
Dec 11, 2022 04:47 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
