2.4ss/sc build commenced!!!
Old May 23, 2009 | 02:54 AM
  #301
Dragonsfire12345's Avatar
lol its a stock pulley, and stock intake.... gonna get a cai asap. exhaust is zzp shortie header, stock dp minus cat, and borla muffler
oh and after I recorded that little preview.... my wideband stopped reading.
Last edited by Dragonsfire12345; May 23, 2009 at 02:54 AM. Reason: Automerged Doublepost
Old May 23, 2009 | 03:09 AM
  #302
elecblue06's Avatar
ahh ok so that explains it lol free up that exhaust and intake a bit more and it'll scoot lol
that sucks about the wideband what brand?
Old May 23, 2009 | 03:10 AM
  #303
innovative
Old May 23, 2009 | 05:52 AM
  #304
Jn2's Avatar
Jn2
Did it hit 7.4 and stay that way? That's normal, it will happens after long wot pulls like during tuning, u overheated the o2 sensor, I called innovate in it, check ur instructions it tells u what to do if ur egt's go higher than the sensor will allow
also if u can wait till July I'll sell u by knn intake, I'll be upgrading to a zzp 3" on later in late June, also I'll see u my lsj throttle body if you want, I'm getting a ls4 one in June aswell
Old May 23, 2009 | 11:51 AM
  #305
yeah I guess thats what I did lol..... Having to much fun driving around last night. I'm just gonna wait and get a 3in intake, ls4. At the same time, figure I just save up and buy that stuff right off the bat instead of spending money on other stuff and then just selling it.
On another note I can't find in the manual where it says what to do
Old May 23, 2009 | 01:35 PM
  #306
rico's Avatar
damn jo jo i wanna see the car lol
Old May 23, 2009 | 02:05 PM
  #307
lol reason why car is running lean at idle, and rich at wot is due to the bank 1 o2 sensor Its dead
Old May 23, 2009 | 03:21 PM
  #308
Zdeuce4's Avatar
im sick of all the fail...fix it!!!
Old May 23, 2009 | 08:34 PM
  #309
Jn2's Avatar
Jn2
Old May 23, 2009 | 09:17 PM
  #310
HunterKiller89's Avatar
qft!
Old May 23, 2009 | 10:39 PM
  #311
so I replaced the o2 sensor, cleared the codes with the trifecta tuner. Then turned car off and turned it back on and its still there.
Old May 23, 2009 | 11:05 PM
  #312
BULLETSSMOKE's Avatar
would anyone be kind to point me in the right direction for this 2.4SC project. looks like fun and ive wanted to be supercharged for a while. the project doesnt seem too hard from what ive seen.
Old May 24, 2009 | 12:57 AM
  #313
oh forgot to say the code is p0171
here is a vid of the car at idle
http://www.youtube.com/watch?v=VYOJKAn9-VI
Last edited by Dragonsfire12345; May 24, 2009 at 12:58 AM. Reason: Automerged Doublepost
Old May 24, 2009 | 02:27 AM
  #314
sounds like a MAF issue to me. Everything is installed fine, right? MAF isnt backwards or anything? Wires are all good? Try swapping the sensor itself out for one you know works perfectly and see what you get
Old May 24, 2009 | 11:09 AM
  #315
the maf is dummy proof only installs one way. Maybe it got dirty, how can I clean it.
Old May 24, 2009 | 11:47 AM
  #316
glen229's Avatar
MAF cleaner at autozone
Old May 24, 2009 | 03:51 PM
  #317
i knew of one member who (somehow) managed to install it backwards and it was causing MAF issues. I didnt bother asking how he managed to do that, but since then, ive always included it in my troubleshooting list of things to check..lol
Old May 24, 2009 | 06:22 PM
  #318
found the problem... it appears that the intake manifold is still leaking on one side. The bolts are tightened down and torqued to specs. We believe the intake manifold is warped. When you put it on, one side would sit flush on the head while the other side doesn't even rest on the other side.
Old May 24, 2009 | 06:43 PM
  #319
rico's Avatar
wtf gayy. man **** and i though u was all good now damn
Old May 24, 2009 | 07:10 PM
  #320
it is good, just a very small leak.... so the car is not running 100%
Old May 24, 2009 | 07:34 PM
  #321
double gasket as a temporary fix maybe?
Old May 24, 2009 | 08:02 PM
  #322
rico's Avatar
ah okay good and ya mayb what hunter said will help
Old May 24, 2009 | 08:29 PM
  #323
good idea but I threw away the old gasket
Old May 24, 2009 | 08:36 PM
  #324
rico's Avatar
ah damn u lol. buy another one? lol
Old May 24, 2009 | 08:47 PM
  #325
by the time it takes to come I could have already taken off the intake manifold and gone to the machine shop to have it leveled.
