2.4ss/sc build commenced!!!
Old Mar 28, 2009 | 04:24 PM
  #226
rico's Avatar
joe joe get the damn car out on the streets im waiting to see damn lol. and damn hah i was able to put my sc on and belt all on my own man lol yall fail haha jk ima txt u later on to see whats up
Old Apr 6, 2009 | 11:32 AM
  #227
Dragonsfire12345's Avatar
so here is where I stand, car is tuned.... but when I start it, it dies right away... if I give it gas it goes from idle-2000rpm back down and up and keeps fluctuating back and forth. While that happens the exaust smells really rich.... and there was some pre-detenation so I went ahead and turned it off.... I was out of town this weekend so had no chance to work on it. I work all day today so can't do anything.... either tomorrow or wednesday we will datalog with trifecta and see whats going on.
Old Apr 6, 2009 | 12:07 PM
  #228
cobaltss86's Avatar
injector problem?
Old Apr 6, 2009 | 12:20 PM
  #229
elecblue06's Avatar
yea sounds like 60's i had that issue but he said he new how to fix it 60's are a pencil style injector which suck bawlz at being easy to regulate
Old Apr 6, 2009 | 01:17 PM
  #230
cobaltss86's Avatar
i think he's running 42.5s
Old Apr 6, 2009 | 02:03 PM
  #231
elecblue06's Avatar
well thats just weird/ silly lol .. you're going to be out of the range of 42s pretty fast me thinks..
Old Apr 6, 2009 | 02:07 PM
  #232
SlowBalt_06's Avatar
happened during becks 2.4 build if i rememeber it was a problem with the tb
Old Apr 6, 2009 | 02:12 PM
  #233
elecblue06's Avatar
ahh thats right.. and isn't he using the LSJ TB... just one more reason to buy things you dont have to rewire lol
Old Apr 6, 2009 | 03:16 PM
  #234
Jn2's Avatar
Jn2
wow that sucks, u sure u wires everythign right? did u soder your connection, and not just wrap wires together
Old Apr 7, 2009 | 01:15 AM
  #235
I have 60lb injectors like this: http://www.ottperformance.com/Fuel-S...duct_info.html
As for TB its the stock LE5 TB, wiring is correct and sodered
and as for the ezflash tuner, I think I installed something incorrect and thats why its not working.
Old Apr 7, 2009 | 11:05 AM
  #236
elecblue06's Avatar
oh well that sucks man.. yea those GT tuners seem to be sucking periodically
Old Apr 7, 2009 | 11:16 AM
  #237
yeah hopefully its just something with the tune, and thats it.
Old Apr 9, 2009 | 01:56 AM
  #238
I got an intake leak somewhere after the supercharger... so... either the map sensor is leaking or the intake manifold to head is.
Old Apr 9, 2009 | 03:33 AM
  #239
cobaltss86's Avatar
damn that sucks but its good you found the problem
Old Apr 9, 2009 | 11:17 AM
  #240
yup now its time to have fun on saturday and tear it down.
Old Apr 21, 2009 | 01:20 PM
  #241
so.... we made sure somethings were tight. Now we did a some datalog readings and vince said there is still either a major intake leak, or the something is wrong with the map. We tested the map sensor witha volt meter. With ignition on both the map signal, and low reference read 5 volts. When we turned the car on the low reference read 5 volts and the map signal reads 4.6 volts. Is that a sign of the map not working?
Old Apr 21, 2009 | 01:55 PM
  #242
Jn2's Avatar
Jn2
Isn't it suppose to be that way? It reads .1-5volts, with the car on it's telling u what it's reading only way to tell is test tyrones map and see if his is like that too
Old Apr 24, 2009 | 11:55 AM
  #243
I was able to scan the car and it had map signal low voltage. So I replaced it.... and well its still not running good.
I got one question for all those that can chime in. Did yall or do you know if on the intake manifold gasket, do you have to cut a hole between the 2 middle ports? When we were doing the build one friend who had a cavalier(2.2eco supercharged) said I had to cut a hole for.... well I forgot what it was for. Did yall do this?
Old Apr 24, 2009 | 12:09 PM
  #244
elecblue06's Avatar
no you dont from what I remember reading other peoples comments on boost.. man that REALLY sucks you're not up and running
Old Apr 24, 2009 | 06:06 PM
  #245
k, maybe thats whats causing the car not run.....
bump my last question!!! lol NEED HELP!!!
Last edited by Dragonsfire12345; Apr 24, 2009 at 06:06 PM. Reason: Automerged Doublepost
Old Apr 24, 2009 | 06:09 PM
  #246
Jn2's Avatar
Jn2
^^^thats mine, did that per the build books instructions
Old Apr 25, 2009 | 01:46 AM
  #247
got some more bad news...... we were trying to get the car on a trailer to tow it to a friends house.... well the radiator some how hit something and broke. Not sure how much damage was done but we will find out tomorrow. I'm having the worst of luck with this build.... The car gods are smiting me lol
so....
I'm gonna take it off tomorrow and see how bad it is. If its fixable I'll fix it... but if its not I might pending the price, buy an aftermarket radiator.
Next question: Where can I buy an aftermarket radiator?
Old Apr 25, 2009 | 03:09 AM
  #248
Jn2's Avatar
Jn2
Custom made or get a universal one on eBay and run custom hoses, by custom I mean those long bendable ones
Inlet/outlet: 1.5"
Also a universal slim fan
Radiator: ~200
fan~30+shipping
Old Apr 25, 2009 | 03:32 AM
  #249
Zdeuce4's Avatar
omg man.. i hate ur car... why must u hit EVERY roadblock in this build?/??
Old Apr 25, 2009 | 05:05 AM
  #250
HunterKiller89's Avatar
so....
only one i know of is from a company called griffin.
