2.4ss/sc build commenced!!!
Old May 26, 2009 | 01:02 AM
  #326
Dragonsfire12345's Avatar
manifold was perfectly fine. Reason for all my trouble were the two bolts that I used for the intercooler pump. They were to long and were hitting the intake manifold and causing it to have a very small leak.
Old May 29, 2009 | 01:30 AM
  #327
last couple of days, I've been datalogging with vince. I might be going to the track tomorrow to see she does in a 1/4 mile.
Old May 29, 2009 | 01:33 AM
  #328
Jn2's Avatar
Jn2
where r the vids @
Old May 29, 2009 | 01:40 AM
  #329
I'll post some up in the morning while I do some datalogging. I was gonna spend all day tomorrow cleaning the car cuz it is just filthy from where it was just sitting there for four months rofl.... Also gonna redo the valve cover cuz it looks like ****.
Old May 29, 2009 | 07:46 PM
  #330
40-85mph
http://www.youtube.com/watch?v=HhIjBmZDpjQ
Old May 30, 2009 | 08:46 AM
  #331
SSMOKEM's Avatar
Originally Posted by Dragonsfire12345
" It looks like I'm running at an incredibly high rate of speed! " Dumb & Dumber
Thats awesome man! Glad to see it running!
Old May 21, 2011 | 02:46 AM
  #332
slobalt08's Avatar
I just got an sc kit and I have some questions.
https://www.cobaltss.net/forums/2-4l...34/index8.html
You guys confused me here. So let me see if I got this right. I wanna make sure I have everything.
Originally Posted by HunterKiller89
the LSJ has a 1 bar that mounts in the blower, and a 2.5bar/IAT2 sensor that mounts in the intake manifold
The sensor "1 bar" that attaches to my SC is broken. http://img707.imageshack.us/img707/9...0521030252.jpg The IM sensor "2.5 bar" opening is blocked by a screw
http://img713.imageshack.us/img713/4...g5340large.jpg I also do not have the sensor for it. So basically are you guys saying that I DON'T need the IM
sensor, and I can use my stock sensor for the SC? Do I need this so called "pigtail" or am I using a stock connection? Cause I see no such "pigtail" in my kit other
than for the throttle body. I also see no connection in my kit that goes to the "1bar" sensor. All I have is injectors with harness, and ic pump wire. I'm probably having it trifecta tuned.
Also my SC kit came with a cx racing h/e. Do I also need the stock lsj h/e? Since I see the OP has one and my kit doesn't. (my IM has a home made dual pass and the kit came with option b)
These are the plugs the guy gave me with the kit are they the wrong ones? http://img834.imageshack.us/img834/9...0521030307.jpg
And one more thing, do I need any of these?
12594387 – LSJ IC Pump Insulator
15253932 – LSJ Power Brake Booster Vacuum Hose (why do I need this what's wrong with the stock hose?)
12584369 – LSJ TB To Purge Solenoid Tube (no idea what this is or if I have it)
Dragon how much did you boost with stock pulley?
Old May 22, 2011 | 12:00 AM
  #333
HunterKiller89's Avatar
if you use the stock 1bar sensor in the manifold's 2.5 bar sensor location, then you will connect it to the factory 1 bar wiring harness (though the wires may need to be lengthened to reach that far). Be sure to tell Vince when you get tuned that you are using the 1 bar sensor and not a 2.5 bar sensor.
one HE is good, 2 is better. You dont need the stock one though. The option B kit is supposed to thread in to the stock HE (theres a tap for it), but there are alternate ways of setting it up. The easiest is with the stock HE.
I cant comment on the plugs..NGK has changed their naming scheme a couple times since ive done my install,and i dont remember what the correct ones are now. factory plugs a couple heat ranges colder should work fine though
you need the insulator (it keeps the pump in its place, otherwise it will just slide out of the mounting bracket)
The hose you will only need if the stock one doesnt reach the location of the new vacuum port on the intake manifold. (any hose will do...it doesnt need to be the GM piece specifically)
Its a narrow, hard (not flexible) black plastic connection, maybe 4-6" long, in sort of a J shape. If you dont have it yet, buy it. You need it.
Old May 22, 2011 | 03:13 AM
  #334
slobalt08's Avatar
The sensor location on the IM is blocked by a screw from the previous owner. The SC sensor location is not blocked, but that sensor broke.
http://img839.imageshack.us/img839/4257/img5367a.jpg
http://img830.imageshack.us/img830/1579/img5368n.jpg
http://img861.imageshack.us/img861/9316/img5399y.jpg
the cx racing has 3 nipples maybe the one on top is for the option B?
http://img830.imageshack.us/img830/2162/img5365e.jpg
http://img38.imageshack.us/img38/2487/img5373d.jpg
Old May 22, 2011 | 03:21 AM
  #335
you're going to have to take out the screw then. the sensor must get a reading from inside the manifold, not on the supercharger.
as for the HE, yea, that top one can be used for the opt B. I wasnt aware CXR came with a 3rd connection on top like the stock HE does
Old May 22, 2011 | 12:47 PM
  #336
slobalt08's Avatar
Ok. So what about the sensor for the SC I have to buy a new one? Or do I just block it off and not use it?
Old May 22, 2011 | 03:03 PM
  #337
just block it off. what you block it with is up to you
Old May 22, 2011 | 03:24 PM
  #338
zerosk8ter83's Avatar
wow so this is joes build post,anywase the sensor on the blower is not needed so just block it off or leave the sensor there. As for the third line on top of the h/e thats a bleed line for the opt b tank. Other things your gonna have to know is you do have to grind a little bit of the block for the tensioner and make sure your injectors look like they work. When i got done with mine one of the injectors had a crack and it misfired so i would suggest you look at them closely and make sure there in good condition.
Old May 23, 2011 | 03:42 PM
  #339
2 years going strong lol
Old May 23, 2011 | 04:44 PM
  #340
dam joe you had it bad
Old May 25, 2011 | 02:30 PM
  #341
slobalt08's Avatar
Is it an ABSOLUTE MUST to upgrade the clutch? i really don't have the money after spending all of it on the sc kit lmao how long will the stock clutch last if u dont change it?
Old May 25, 2011 | 02:52 PM
  #342
just stay off the throttle and itll be fine. no clutch dumps, no agressive shifting, and instead of WOT, go like 70% throttle, and the clutch wil be good. But im sure you want to do all those things, so go get a new one!
Old May 25, 2011 | 04:13 PM
  #343
elecblue06's Avatar
i was rocking stock clutch for like 15k boosted ad when i got it replaced it had more life left in her .. it's all how you drive... my clutch had like 82k on it when i replaced it and the clutch master cylinder went out at 12k and puked hydrolic fluid on it lol but it still had life lol just a few hot spots
Old May 25, 2011 | 05:13 PM
  #344
slobalt08's Avatar
Thanks for the tips! Unfortunately I don't have the $ now for one as I spent it all on my sc build lol
18k on my balt... that gives me some confidence
Old May 25, 2011 | 05:14 PM
  #345
Zdeuce4's Avatar
dont buy boost if u cant upgrade ur clutch
Old May 25, 2011 | 05:16 PM
  #346
slobalt08's Avatar
little too late for that now lol
Old May 25, 2011 | 05:25 PM
  #347
Zdeuce4's Avatar
dont push the man pedal then.
Old May 25, 2011 | 05:39 PM
  #348
slobalt08's Avatar
but... but... a few times won't hurt right? lol what clutch do you guys recommend?
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
