2.4ss/sc build commenced!!!
Old Apr 25, 2009 | 10:16 AM
  #251
elecblue06's Avatar
yea there was a company i found tat was starting to make aluminum ones for us
Old Apr 25, 2009 | 03:56 PM
  #252
DFZ24's Avatar
sorry that i didnt read the entire thread but i just want to know if do i really need all the parts that says in How to supercharge 2.4L
or it can be done with main parts, i.e m62, belt, manifold, etc etc
because that a lot of parts in that list.
Again sorry i didnt read the entire thread
Thank you
Old Apr 25, 2009 | 06:46 PM
  #253
scottyguy401's Avatar
Yes you need all of those parts lol
Old May 9, 2009 | 02:07 AM
  #254
Dragonsfire12345's Avatar
here is a vid of how the car is running....
http://vids.myspace.com/index.cfm?fu...deoid=57091300
vince from trifecta says the datalogging shows
"no vacuum in the intake manifold according to the MAP sensor"
Old May 9, 2009 | 06:27 AM
  #255
HunterKiller89's Avatar
busted MAP sensor then? any CELs on?
Old May 9, 2009 | 10:58 AM
  #256
map sensor low voltage- cleared and didn't come back(brand new sensor, lsj map sensor(one that goes on top of the sc)
p0131- I believe was another something about the 1st bank o2 sensor
Old May 9, 2009 | 02:58 PM
  #257
im not sure why, but it looks like your brand new MAP isnt working. try using the stock one (just have a friend hold it in place and start the car, then see if you still have the same issues). If the problem persists, let me know and ill try and think of other possibilities
Old May 11, 2009 | 01:57 AM
  #258
I was told, that I have a boost leak somewhere. Around the map sensor, intake mani-head, or sc-intake mani. I would've looked for it today but it being mothers day I had no chance to look at it. Hopefully I'll look at it on wednesday night.
Old May 11, 2009 | 03:14 AM
  #259
Jn2's Avatar
Jn2
It's post blower pre engine
Old May 11, 2009 | 08:12 AM
  #260
stenguyen1's Avatar
hey doesn't his tb look like its upside down?
and i would check the map sensor and the whole on top of the sc also.
Old May 11, 2009 | 11:37 AM
  #261
if the tb were to sit opposite the way it is now, the ac lines would hit and it won't mount up. I'm gonna check everything(hole on top of sc, map sensor, and other possible areas) hopefully on wednesday night.
Old May 11, 2009 | 07:42 PM
  #262
looks like its on upside down and backwards to me. It will definitely fit when oriented correctly...it has on everyone else's car...lol
The TB has a gasket in place, correct? the little rubber one? Same for the m62?
Old May 11, 2009 | 08:39 PM
  #263
The throttle body is definitely on backwards! The plug should be at the bottom facing the back of the car. It will fit.
Old May 12, 2009 | 12:29 AM
  #264
does it really make a difference?
Old May 12, 2009 | 01:09 AM
  #265
i honestly cant even figure out how you'd mount it backwards. upsidedown i dont think would make a difference, but you never know. it doesnt hurt to just do it right anyway..lol
again, while the TB is off, make sure the robber gasket is in place
Old May 12, 2009 | 02:17 AM
  #266
fine, I'll put it on the right way lol.....
Old May 12, 2009 | 02:34 AM
  #267
Jn2's Avatar
Jn2
Yes it makes a differnce...the tb won't line up right with the blower inlet...we'll figure it out dude...wait till Friday...we'll get it down to the track
Old May 14, 2009 | 01:21 AM
  #268
found the boost leak, sprayed carb cleaner on alot of areas. Boost leak is from intake manifold to head. Its leaking from the sides really bad....ordered new gasket today, and gonna pick up better bolts for the intake manifold
Old May 14, 2009 | 07:52 AM
  #269
stenguyen1's Avatar
hey u could use your stock bolts for the manifold but put some thick washers on there. thats wat i did. and hey do u still have ur 2.4 manifold?
Old May 14, 2009 | 09:22 AM
  #270
elecblue06's Avatar
least you finally found it man
Old May 14, 2009 | 11:47 AM
  #271
I'm just gonna go buy some new ones tomorrow morning.... I already sold the manifold the day it came off lol
Old May 15, 2009 | 08:46 PM
  #272
ok..... so..... I come to the idea... that some where I pissed off the car gods..... I don't know how but I did....
Anyways this is whats going on..... The intake manifold gasket I ordered on wednesday, won't be here for a while. Its on back order, called dealership this morning and he said its on back order and will probably take a while to get in.
Old May 15, 2009 | 08:55 PM
  #273
wesg631's Avatar
im thinking you did too how long has this been going on maybe you should sell th supercharger stuff and go turbo
Old May 15, 2009 | 09:05 PM
  #274
lol tell me about it... sell everything... and get the zzp stg 2 kit.
maybe the car wants to go psssssh.... instead of whining all the time
Old May 15, 2009 | 09:30 PM
  #275
Jn2's Avatar
Jn2
do it...just sell ur sc kit
