2.5 exhaust opinions
Old Aug 16, 2012 | 07:52 AM
feerme7's Avatar
Old Aug 16, 2012 | 08:38 AM
hhrfreek's Avatar
https://www.cobaltss.net/forums/gene...-model-254160/
Old Aug 16, 2012 | 08:58 AM
feerme7's Avatar
Thanks! Ill have to check it out after work
Old Oct 7, 2012 | 03:43 AM
slobalt08's Avatar
Originally Posted by feerme7
Not spending $900 on exhaust for a cobalt. If anything I'll just stick with my stock catback, I already have the muffler on anyways.
I just figured having the 2.5" piping would make flow better.
But not worth $900
see this is what i wanted to do. i already have a magnaflow muff and res on stock piping. i wanted to get the exhaust tubing http://www.mandrelexhaustsystems.com...EXHAUST/Detail from them to replace the stock. so you guys would not recommend that?
Old Oct 8, 2012 | 10:37 PM
06Cobalt2.4's Avatar
Here's my build, from the header back. Mind that I live in Kansas, which is currently free of emissions testing:
>Custom Header (Inlet/ Outlet: 1.625" X 0.875" (Oval)/ 3.250") - Part: $110 - Labor: $0, done myself
>Resonator Delete (Replaced with 2.5" piping) - Labor: $20 for 30 minutes
>Catalytic Converter Delete (Replaced with 2.5" piping) - Labor: $40 for 15 minutes and an illegal act [:
>Cut Axle-Back piping, (Replaced with 2.5" piping) - Part/Piping: $25 - Labor: $40 for an hour
>Magnaflow Muffler with stock SS tip - Part: $116 - Labor - $20 for 30 minutes
Total cost for my custom header-back exhaust: $255
I have a guy thats about a 20 minute drive from my house at Big O Tire that welds for pretty reasonably cheap.
Old Oct 8, 2012 | 11:34 PM
slobalt08's Avatar
still awaiting for an answer
Old Oct 9, 2012 | 03:20 PM
imo.. I would only do that if you can hire a cheap welder o.O
Old Oct 9, 2012 | 03:35 PM
CordiaDOHC's Avatar
I liked my slp catback with the factory manifold and downpipe. But with the zzp shorty and the cti 3" to 2.5" catted downpipe its ungodly loud and even just letting off the throttle on the highway for 10-15 seconds while in drive results in small pops
But when the car is turned off and sitting in a parking lot the system does look fairly stock
the slp is 2.5" stainless steel and 400 bux shipped.
Old Oct 9, 2012 | 07:36 PM
slobalt08's Avatar
I hit a big rock that i didnt see cause it wad night timeand it put a nasty dent right where the over axle begins that's another reason i wanna do it. I was told it shouldn't cost more than $30?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
