Ati Super Damper
Old Aug 13, 2008 | 05:18 PM
Evil C's Avatar
Ati Super Damper
http://www.atiperformanceproducts.co...ts/damserp.htm
ATI Super Damper it claims a 12% under drive i have a few questions pertaining to this. Is this drivewayable job?
On a scale of 1-10 how hard would you say it is on these cars (transversly mounted is a bitch in the pulley department).
Is it a notable gain?
Does it require any thing like a rebalencing ect?
Old Aug 13, 2008 | 05:34 PM
Pickles's Avatar
Serpentine???
Old Aug 13, 2008 | 09:02 PM
bigworm's Avatar
its easy to do, but may not be worth the money for 2-3hp.
However, do a before/after dyno and post your results.
Old Aug 14, 2008 | 10:38 AM
nutsandboldts05's Avatar
its nto for the 2.4L engine though?
Old Aug 14, 2008 | 03:23 PM
Evil C's Avatar
Correct its for the 2.2 however unless im mistaken it should fit all ecotecs.
Im not really looking to this mod for more hp so much as less rotating mass leads to quicker revving engines which inturn should lead to better responce.
However i wouldent want to "booger it up" so it wouldent be a reliable daily driver. Ive seen what happens to cars with bad or wrong Harmonic balencers (picture an earthquake in your car)
Old Aug 14, 2008 | 07:10 PM
hoffa's Avatar
i saw no LE5, not for us yet
Old Aug 14, 2008 | 07:12 PM
joeworkstoohard's Avatar
i don't see why it wouldn't fit an LE5, IIRC, the pully is the same.
Old Aug 14, 2008 | 10:33 PM
domin8_gt's Avatar
LSJ is based off of the L61. LE5 has many differences. LNF is based off the LE5. L61 gets the LE5 treatment by way of VVT for 2009.
Hope that helps clarify some stuff.
Old Aug 15, 2008 | 11:36 AM
Evil C's Avatar
yeah but the bottom end is essentially the same but the bore correct?
Old Aug 18, 2008 | 11:53 AM
bigworm's Avatar
this is all true, but they are still in the ecotec family and all interchangeable to a degree.
the only difference between the LSJ crank pulley and the LE5 is the number of ribs and overall diameter. the L61 crank pulley is identical to the LE5. I havent seen an LNF pulley yet, but i would bet money on it being the same as the LE5/L61
Old Aug 20, 2008 | 01:24 PM
WhiteSSBalt's Avatar
Not a Sebring
Subscribed.
Oct 13, 2015 09:32 PM
DANRICKARD
Oct 1, 2015 12:08 AM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
