Bog In My 2.4
Bog In My 2.4
I have an 06 2.4 with a coi and magnaflow catback , for the past month of so i've had a distinct bog , it almost sounds like a putter . Anyone had this before?
It might be your filter. How long have you had your cai? Also header and downpipe will get rid of more hesitation/bog. Then get a tune either trifecta or hp tuners. I do know what you mean though my g5 gt did that to when it was stock, but once i got mods done to let it breath better it wasn't as bad. Ultimately you need a tune to really wake up your car.
Its not even a hesitation , i can be in any grand at any rpm and it will still spudder . and my check engine light will flash , somethings goin on there. where in ns can you get a 2.4 tuned and what differance does it make?
That sounds like either your injectors or coil pack. Go to the dealership asap!
Flashing check engine light is always a misfire. Whether what is causing it is a different story. Like olivecj stated, it may be coil packs but if your car is under warranty, def take your car to the dealership.
I ordered my tune through Trifecta Performance and they send you either a cable that you plug into your laptop or they can send you the actual gt tuner programer. I went with the gt tuner it was very easy to do and my car performs awesome now. It made a tremendous difference especially since i'm a auto so my tranny was also tuned for firmer quicker shifts. If you do get a tune make sure you have full bolt ons first like, intake, header, downpipe, and exhaust. That way you'll get the maximum hp possible out of your car.
I can almost hear a leak developing in my exhaust , but it is the stock downpipe . i had replaced it a couple months ago because it has broke , i had the car put on the scanner the other day and it showed up the gas tank vent sylinoid ? so i ordered one , you guys are guessin misfire?
Getaway_Driver
Sep 8, 2015 09:41 AM
