View Poll Results: Which set up is a better bang for the buck?
CA - The collector won't matter
14
35.90%
ZZP - Your exhaust is as big as its smallest point
25
64.10%
Voters: 39. You may not vote on this poll
CA vs. ZZP Headers
CA vs. ZZP Headers
Well, I've been looking into my various header options and I've narrowed it to:
A) CA v1 Header+XTC DP (1.7" Primaries, 2.25 Collector. 2.5 DP Exit w/ hi-flo cat & stainles steel) (COME WIDEBAND READY) $500 SHIPPED.
B) ZZP Header & DP COMBO (1.5 Primaries, 2.5 collector & DP exit. w/ hi-flo cat & stainless[+$70] & wideband opt. [+20]. $509.99 PLUS SHIPPING.
{369.99+20forwideband+70forstainless+50forcat=509. 99 not including shipping}
Now, so far, CA seems like the better deal right? !!!BUT!!! the header only has a 2.25 collector...so my question is(I've heard that your exhaust is only as big as its smallest point) will having this make the rest of my exhaust useless as if i have 2.25 all the way back? Any help is appreciated, THANKS!!!
Here's what a good friend of mine who owns a custom exhaust shop has told me.
2.25 inch exhaust is good for about 225hp
2.50 inch exhaust is good for about 250hp
3.00 inch exhaust is good for about 300hp
Now this man has been building custom systems AND racing for the past 20 years that I know of and I feel confident enough in what he has told me to pass it along. So if your 2.4will exceed 225 hp then you may need to have a 2.5 inch collector. But as I stated above a compitent exhaust shop CAN replace the CA 2.25 collector with a 2.5 one no problems! And the 1.7 inch primaries will do you better then 1.5 ones.
Do you know Witt on here (Al) he had some done for an LSJ and I think the dude would do some for the FE5? VERY reasonably priced. Wouldn't hurt to cover all options.
I opted for the 1 3/4" primaries, ceramic coating, SS dp, highflow cat and the extra bung for my WB, so it was a bit costly, but,
I've always believed you get what you pay for. And I can't wait to get this baby installed
I hated my XTC Downpipe. The cat emptied out on its own... so I wasted money by buying the version with the cat... and then the welds busted and it leaked like hell.
ZZP is a very good company... well respected and loved in MANY automotive worlds.
If you go ZZP replace every bit of hardware they supply. I used their bung plug... thing came right out. Used the supplied washers and they melted around the bolts causing a leak where the header meets the DP. Luckily I had already replaced the bolts because they are known to break. Go to Lowes and buy stainless lock washers, nuts and bolts. I think its a 3/8-16. 1.5 inch long. Header and downpipe are quality crafted though, good welds. Oh, and the collector is 3" not 2.5". Also I think the vers. 2 CA has a larger collector if you're daring.
There is nothing wrong with a 2.25" collector. Exhaust nauturally flows to more open areas so if you go 2.5" catback it may help your scavenging effect plus you'll retain most of your low end. I wanted a little more uptop so I went with the 1.75 ZZP. I'll probably cam/blow it.
What are the benefits of the zzp mid length header downpipe combo vs the vibrant header and downpipe? It sorta seems that for the same price the vibrant is all stainless whereas the zzp is only stainless downpipe. I could be wrong.
z28addiction
Sep 28, 2015 12:03 AM
