Cams for 2.4?
Old Mar 5, 2008 | 12:39 AM
Coolbalt SS's Avatar
i kno a guy that could install but it doesnt sound like the way to go. may have to go FI, which isnt so bad!
Old Mar 5, 2008 | 02:03 AM
elecblue06's Avatar
i'm thinking about doing cams eventually something about a 220 or so whp N/a build would be sex lol
if you look at redfocz numbers he has 186 whp on a mustang dyno so with cams an head work that'll be awesome..
however is it possible to get cams ground that'll work for na as well as sced?
Old Mar 5, 2008 | 02:05 AM
steddy2112's Avatar
Nothing drastic...just do a mild cam and it'll work...these heads flow like poo, a good port job on em really opens em up
Old Mar 5, 2008 | 02:13 AM
elecblue06's Avatar
exactly.. from what i hear the exhaust ports are tiny as hell stock and a nice port would do wonders.. i mean it might be a good 2K for cams and a p&P head sans install but it should result in about 25 or so whp i would think...
i'm a bit cam stupid and it doesn't help there are no options for us... what would be a "mild cam setup"?
/ how much approximately would you estimate a custom grind would cost?
Old Mar 5, 2008 | 02:20 AM
steddy2112's Avatar
Mild would be a slightly more amount of lift/duration
A machining place(where you could get your head done) would do it...150-300 bucks for the grind, and you'd have to buy blanks
Old Mar 5, 2008 | 02:33 AM
elecblue06's Avatar
hmm thanks for the info would the triflows be considered wild cams? and how much gain would a mild set approximately be? i know it's ricer math for 700 -1500 bux for cams and the port giving a 20 hp gain na and huge potential for boosted would be well worth it to me
Old Mar 5, 2008 | 12:06 PM
IonNinja's Avatar
typically you don't want to use NA cams on a boosted motor because they yield poor results due to their grinds specs.
if you want to go supercharged then get some cams that work well with a blower.
now if the cam is mild, as stated before with maybe stock lift and more duration or something similar you may be able to get away with it. i'd ask some LSJ guys with cams and see what they think...
Old Mar 5, 2008 | 12:43 PM
REDFOCZ's Avatar
Here's JBP's responce to what is need with there cams. Click Here
Also if you buy some blank cams, you can call Crane Cams in Daytona beach Fl they have about 3 or 4 differant cam grinds from Mild to Wild. And they dont charge too much I priced them out to be just under $600 shipped and everything.
Old Mar 5, 2008 | 12:45 PM
HawkMThe's Avatar
Originally Posted by Coolbalt SS
wow. im not lookin forward to 3k for 15 hp.
If you are going to spend that much you miles well just say another couple hunred for a turbo.
Old Mar 5, 2008 | 05:49 PM
Jimmys2007CobaltSS/C's Avatar
u mine as well get the hahn stg 2 turbo kit for that money and get 100 whp
Old Mar 5, 2008 | 06:04 PM
  #36
SSam2.4's Avatar
If it were me I'd go turbo first and build the motor when it was needed or could be paid for .
Old Mar 5, 2008 | 08:07 PM
  #37
elecblue06's Avatar
hmm if i remember correctly can't the lnf cams be used in the le5? or was that just a rumor? if so would that be a decent alternative? probably only on a turbo'd engine?
just something i've been tossing around that i think would be nice
Old Mar 5, 2008 | 08:12 PM
  #38
steddy2112's Avatar
Exhaust cams are swappable.
Would be best left for a turbo application.
Old Mar 5, 2008 | 10:40 PM
  #39
elecblue06's Avatar
thats what i figured :-) thanks man you've been a great help
Old Mar 5, 2008 | 10:42 PM
  #40
steddy2112's Avatar
I do what I can
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
