Cobalt 2006 N/A - SWAP TO BETTER ENGINE ????
Old May 8, 2014 | 10:03 AM
Themoooseee's Avatar
Question Cobalt 2006 N/A - SWAP TO BETTER ENGINE ????
Hi everybody, i have a cobalt SS 2006 N/A, had a problem the other day, out of nowhere, oil light popped out for maybe 0.03 seconds and since then, i can hear the crank knocking in the engine, first taugh it was a problem over the timing chain (i was hoping) but after more check ups, we found out that the crank had a problem (we could feel the crank knocking while touching the gas and putting and hand on the bottom of the engine, we could even feel it. THAT SAID ! I NEEED AN ENGINE SWAP ! I can't realy find any thread on my exact problem so i was wondering what was the BEST engine i could put in, would you guys go back with the 2006 N/A 2.4 engine or would you guys go for any engine with a S/C or T/C ?? Let me know guys, im doing the engine swap latest next week so it gives me a week to make sure on which engine to put in ! THANKS !!
Old May 8, 2014 | 10:08 AM
redcobalt07's Avatar
keep the same engine you had in it, the wiring to swap to another ecotec engine would be more hassle than just getting another car
Old May 8, 2014 | 10:19 AM
Thats pretty much where i was aiming to, keeping the same engine (well replacing with a new 2.4 i mean) at that point, to have a bit more fun with it, what would be the simple stuff i could had up to the engine to have more fun/power with it ?
Old May 8, 2014 | 10:23 AM
like an intake, header, exhaust, tune
Old May 8, 2014 | 10:32 AM
ok then ill go back to what I had ! hahaha !
Old Jul 16, 2014 | 02:02 PM
Ceeker's Avatar
changing to LSJ or LNF will require a rewire, which is a very time intensive process, paying someone to do it is $$$. Mitchell1 is pretty much the standard for wiring diagrams. but membership is $$$, if you poke around you might be able to get a login.
i would try and find a 2005-6 LE5, here they are in junkyards for a $200-300
the 2006 LE5 has stronger rods/pistons, so if you do want to mod it down the road it will handle power better.
WhineSSbaby
Sep 1, 2020 12:39 PM
GaryGibblez
Jan 14, 2020 10:35 AM
jcalvin1126
Sep 11, 2015 10:24 AM
soundjunky
Sep 3, 2015 01:18 PM
