coolant leak
Old Mar 26, 2007 | 02:23 AM
elmstreet's Avatar
coolant leak
did anyone else run into this problem when installing their CA header?
Old Mar 26, 2007 | 09:18 AM
rlinden86's Avatar
huh?
how do you have a coolant leak did you cut something or is the header touching something. i shall have to see that one cuz im getting the ca header should be about 2 days.
ryan.
Old Mar 26, 2007 | 09:26 AM
D4u2s0t's Avatar
need some more details... simply installing a header should not cause a coolant leak in any way.
Old Mar 26, 2007 | 09:35 AM
WSFrazier's Avatar
Someone locally here went to install a header, not sure what one. They said when they did, almost a qt of coolant came out from somewhere. I don't see how but it has happened.
Old Mar 26, 2007 | 09:36 AM
joeworkstoohard's Avatar
i remember hearing that some hose gets in the way. i'm thinking that it was for the heater. but i'm just going on what i think that i may have read sometime once before. not very scientific.
Old Mar 26, 2007 | 03:49 PM
elmstreet's Avatar
there is also a crossbar type thing under the header that the header rubs against.. im thinking maybe the old one should go back on..
Old Mar 26, 2007 | 03:50 PM
06blackg85ss's Avatar
please use the search function... I"ve already posted up the fix at least 10x's I'm not typing it again
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
