difference
Old May 22, 2006 | 04:27 PM
spade44's Avatar
difference
what is the difference between a Cold Air Intake and a Short Ram intake?
Old May 22, 2006 | 04:31 PM
06G5GT's Avatar
The short ram takes air from inside the engine bay which is warm.
The cold air routes the filter to down inside the bumper area where cooler air can be ingested for a little bump in power.
Old May 22, 2006 | 04:36 PM
CTCOBALTSSS's Avatar
You want a cold air intake! The cone at the end of a cold air intake sits ferther away from the motor than a short ram intake. Motors work better and produce more power with colder air. Picture yourself jogging. If you had cool air to breath rather than hot air, you are going to jog faster and longer than if you had to breathe in hot air. Go with the cold air intake. Also known as a "CAI" Short for Cold Air Intake. Here are pics of both.
SHORT RAM INTAKE
COLD AIR INTAKE
See how the cold air intake is burried away from engine heat? Much better!
Old May 22, 2006 | 07:01 PM
savior's Avatar
being a runner that i am, i'd prefer running in warmer weather.. the cold air is too harsh on runners lungs FYI
anyways, i'd go for short ram because of the following reasons
1) it makes the egine look nice
2) its cheaper but performs around the same HP gains (1-2 hp difference)
3) it benefits the low end a little more (air has to travel less distance)
i wouldnt buy a CAI because:
1) its $$$
2) the air is warmed up by the time it reaches the engine because the metal piping on a CAI conducts the same temperature in the engine bay - therefore if your engine is 190*, your piping will be 190*, thus warming up the air anyways
3) CAI tends to "lag" or not produce a lot of power in the low rpms because the air has to travel further
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 28, 2015 12:51 PM
