ECM question
Old Aug 5, 2009 | 04:39 PM
slobalt08's Avatar
ECM question
Would I be able to swap my 08 Sport ECM with an 07 SS/NA's? The reason being so HP tuners can work on it, since it doesn't for the 08 ECM. I know I know trifecta, but I'd like it better if I could have my buddy tune me.
Old Aug 5, 2009 | 05:28 PM
riko540's Avatar
The short answer is no because the ECM's have completely different pin layouts. The long answer is yes however you'll end up spending more than its worth to rewire the entire car.
Old Aug 5, 2009 | 06:44 PM
slobalt08's Avatar
Blah.... Ok thanks.
Old Aug 5, 2009 | 09:30 PM
riko540's Avatar
I've seen similar questions asked. Its the same if you wanted to swap out the engine to one other than a 2.4L. It requires the ECU that goes with that particular engine and also requires the car to be rewired, it sucks that they don't offer the Ecotec engines as drop in crate motors with a standalone ECU.
Old Aug 6, 2009 | 03:56 AM
slobalt08's Avatar
Another fine GM fail...
Old Aug 6, 2009 | 10:58 AM
Red07SSNA's Avatar
agreed...the reason the Chevy smallblock was/is so popular is because you can mod the HECK out of it if you want to. Hard to believe Chevy lost touch with that idea...probably thank the Government emissions regulations though...
Old Aug 11, 2009 | 01:09 PM
gulf2vet03's Avatar
Where is the ECU Located for the 2.4? And is it easy to remove?
Old Aug 11, 2009 | 01:48 PM
Dunkinuts's Avatar
its in the engine bay just in front of the fuse box.
as for tuning a 08 there is LS2edit and trifecta, those are your only options.
Old Aug 11, 2009 | 02:25 PM
gulf2vet03's Avatar
Having ECU Issues so I have a new one. Is it a problem just to swap the ECU with the new one? It should work normal if its the same one correct? I have the 2.4 NON SC 2006
Old Aug 11, 2009 | 05:59 PM
riko540's Avatar
theoretically yes it should.
Old Aug 11, 2009 | 09:25 PM
gulf2vet03's Avatar
I found an ECU with 17,000 miles and its an identical 2006 cobalt SS 2.4. This should be an even swap with out any need of some kind of preprogramming from a dealer does it?
Old Aug 11, 2009 | 11:39 PM
Red07SSNA's Avatar
Not sure about that...could be a problem when "communicating" with the other modules since the VIN is different or it may not have all the same RPOs/options. You can try it...and let everyone know if it works.
Old Aug 11, 2009 | 11:41 PM
outtamymind's Avatar
if i'm not mistaken the ecm has to be reprogrammed with your cars vin in order for it to work correctly.
Old Aug 6, 2010 | 03:08 PM
slobalt08's Avatar
I have a new question. What ecm does the 08 sport have? E67 E37 or E97?
Old Aug 7, 2010 | 08:27 AM
BennyHHR's Avatar
E37 and don't even consider a swap.
BTW, HPTuners now has E37 support in beta!
Old Aug 7, 2010 | 06:08 PM
slobalt08's Avatar
That's why I asked.
Old Aug 9, 2010 | 12:02 PM
DaBuzzard's Avatar
saaaaaWEEEET!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
