Ecotec Underdrive Pullies?
Old Jan 1, 2006 | 10:22 PM
RaineMan's Avatar
So.... has anyone heard about any underdrive pullies for the N/A Ecotecs? I'd like to find one for the AC compressor... maybe some other stuff.... try and gain some power that way. Opinions?
Old Jan 3, 2006 | 10:37 AM
celicacobalt's Avatar
stay away from them if this is your daily driver, for a weekend racer only these may be good for the 2 hp they produce
Old Jan 3, 2006 | 10:45 AM
R33P3R007's Avatar
360 L337 User
like he said^^ not such a great idea if you wanna drive it all the time
Old Jan 3, 2006 | 06:04 PM
RaineMan's Avatar
heheh.... thanks for the info... but if I can find one for the A/C compressor I'll probably get it... just because I rarely ever run the A/C anyways... even in the summer... I prefer windows down, roof open.
Old Jan 3, 2006 | 06:07 PM
MacG321's Avatar
i think pullies will produce more than 2 hp on the n/a ss.
Old Jan 4, 2006 | 10:18 AM
i was being sarcastic
Old Jan 4, 2006 | 07:29 PM
RaineMan's Avatar
So... this still leaves the question... are there any underdrive pullies out there?
Old Jan 5, 2006 | 12:09 AM
97cavie24ls's Avatar
if the 2.2 pulley would fit then the crank and alt pullies are all you will find
the a/c would require alot of work to make and change , plus the a/c doesnt really draw any power down when its not being used
Old Jan 5, 2006 | 12:16 AM
zinner's Avatar
Moderator Alumni
What he said ^^^^
Most AC units have a clutch that engages the AC pulley only when the AC is turned on.
The cobalt also doesn't have a PS pump to drive either so even less draw on the crank.
Go electric power steering!
I have seen you can gain some horse from replacing the balance shafts with a racing neutral balance shaft and thant can pick you up some power. GM claims it takes 10 HP to drive the balance shaft on the LSJ.
Barkleyj605
Oct 24, 2015 12:07 AM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
hhrfreek
Sep 11, 2015 01:28 PM
