Engine and Trans mounts
Hey does anyone have a link to instructions on how to put those things in?
Im asking cause i would like to get some but then not beable in install them cause i dont have the proper tools or im kinda mechanically inclined.
Anyone put them in on their own? Was it hard?
Thanks
Thanks
mounts
i just got my zzperformance engine and trannie mounts last thurs. they are fairly simple to put but if you have the LE5 the 2.4L motor the front mount wont fit its for the LSJ motor the2.0 but the top engine mount and the back tans mount are simple to do. and a major improvement in the hooking up department engine vibes are very noticeable tho 16mm and a 18mm wratchet and a torq wrench to tighten things up at the end should be all you need
cool cool yeah i gotcha i just wonderd if you or somebody you had one or the other and knew one was better my zzp mounts had really bad vibes but there starting to go away now after about 200 miles ill say they are sweet no more of my motor sounding like its banging off my radiator and firewall when i shift hahaha
i did mine myself the holes in the rear tanny mount werent threaded deep enough for the stock bolts so i taped them a lil futher and not by just tightening the bolts so they make new threads lol gonna have to get a front trannie mount insert because the zzp front trannie mount is only for the lsj motor so i still have a floppy front mount. mine are starting to break in a lil and the vibes are goin away.
patooyee
Oct 1, 2015 01:07 PM
