Engine and Trans mounts
Old Nov 15, 2008 | 07:08 PM
boose88's Avatar
Hey does anyone have a link to instructions on how to put those things in?
Im asking cause i would like to get some but then not beable in install them cause i dont have the proper tools or im kinda mechanically inclined.
Anyone put them in on their own? Was it hard?
Thanks
Old Nov 15, 2008 | 07:11 PM
shutzero's Avatar
upper engine mount
https://www.cobaltss.net/forums/show...ighlight=mount
trans mounts
https://www.cobaltss.net/forums/show...t=trans+mounts
mine for sale
https://www.cobaltss.net/forums/parts-66/fs-turbo-tech-racing-solid-upper-engine-mount-141381/
Old Nov 16, 2008 | 10:08 AM
wball09's Avatar
mounts
i just got my zzperformance engine and trannie mounts last thurs. they are fairly simple to put but if you have the LE5 the 2.4L motor the front mount wont fit its for the LSJ motor the2.0 but the top engine mount and the back tans mount are simple to do. and a major improvement in the hooking up department engine vibes are very noticeable tho 16mm and a 18mm wratchet and a torq wrench to tighten things up at the end should be all you need
Old Nov 16, 2008 | 01:19 PM
boose88's Avatar
nice links thanks fellas
Old Nov 17, 2008 | 12:10 AM
hoffa's Avatar
ttr is the way to go.
Old Nov 17, 2008 | 03:37 PM
wball09's Avatar
why ttr nothing against them just wondering what is the difference in their mounts and zzp mounts?
Old Nov 17, 2008 | 10:40 PM
BoostedG5's Avatar
ill say TTR, no evidence to prove they are "better" but i will say they do their job damn well.
Old Nov 18, 2008 | 09:38 PM
wball09's Avatar
cool cool yeah i gotcha i just wonderd if you or somebody you had one or the other and knew one was better my zzp mounts had really bad vibes but there starting to go away now after about 200 miles ill say they are sweet no more of my motor sounding like its banging off my radiator and firewall when i shift hahaha
Old Nov 18, 2008 | 09:40 PM
TurboTechRacing's Avatar
Did you get them installed I have yet to see your cobalt in Rochester when I am over that way...
Old Nov 18, 2008 | 11:09 PM
NWAE Cobalt's Avatar
just got mine installed
both engine and tranny mounts...is pretty viby but its okay... WAY WORTH IT!!!!
Old Nov 19, 2008 | 03:06 PM
wball09's Avatar
i did mine myself the holes in the rear tanny mount werent threaded deep enough for the stock bolts so i taped them a lil futher and not by just tightening the bolts so they make new threads lol gonna have to get a front trannie mount insert because the zzp front trannie mount is only for the lsj motor so i still have a floppy front mount. mine are starting to break in a lil and the vibes are goin away.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
