exhuast
Old Sep 8, 2007 | 08:55 AM
yoppzilla's Avatar
exhuast
confused about the high flow catdownpipe and a cat back exhuast. Is best to have both(which I would think) or just a reg exhuast with a highflow cat or a reg downpipe with a cat back exhuast. Seems like to many cats lol, was not sure if they where going to benifit eachother or work against eachother if both had cats on them
Old Sep 8, 2007 | 09:00 AM
NJHK's Avatar
Note: You shouldn't buy a catalytic converter thinking it's really high flow, cause they aren't any different than your stock catalytic converter, that's why they are 50 state legal. The only reason to buy a so called "high flow cat" is to keep the same diameter as the rest of your exhaust system so it's not a bottleneck.
Old Sep 8, 2007 | 09:09 AM
D4u2s0t's Avatar
well, either way you'll only have 1 cat. and of course the lest restriction, the better the flow, which ='s more power. so you don't HAVE to do a downpipe/catback combo, but it would be better than just a downpipe or just a catback
Old Sep 8, 2007 | 09:31 AM
yoppzilla's Avatar
SO Your Saying THeirs A chance!!!!!
nah so basically according to what exhuast I would be getting would tell me what size or type of downpipe I would need, And if I was to get a exhuast on a stock downpipe their would be more retriction of air flow due to "bottleneck" on the pipe
Now I think I under stand it a lil better thanks fellas
Old Sep 8, 2007 | 09:33 AM
D4u2s0t's Avatar
yep. just make sure all your exhaust parts you buy are the same size. like don't get a 3" downpipe and a 2.5" catback.
Old Sep 8, 2007 | 09:41 AM
yoppzilla's Avatar
right because it would defeat the purpose of retricted air right
Old Sep 8, 2007 | 10:00 AM
Projekt's Avatar
Correct! + also whenever u get exhaust ur exhaust note will change..so look for what kinda sound you want I.E Magnaflow=Honda, SLP=Camaro :P
jmelton327
Sep 25, 2015 09:44 AM
Jroy326
Sep 1, 2015 07:37 PM
Switt23
Feb 13, 2007 12:21 AM
bhowman1980
Aug 12, 2006 12:42 PM
juststickit124
Aug 3, 2006 12:33 AM
