GM Performance Camshafts
So I was reading the GM Performance book the other day and noticed they had Performance Camshafts for the Cobalt. Any info on these? LSJ? LE5? Power gains?
These cams are specifically for the L61 engines through the 2006 model year. The L61 cams in 2007 have completely changed, and are not compatible. LSJ and L61 (pre 2006) cams are interchangable, but their timings are different, so some adjustable gears would be helpful.
Haha, nice. That sucks, I was hoping to order some performance camshafts and put em on. Oh well.... by the way, do we have a price estimate on JBP's cams? I see that install will be about 150, the cams themselves 600+, core charge 250, and timing chain tool 250?... Is it really this expensive for a set of god damn cams??? Why do we not have ANY aftermarket support including turbos!!!???
can soem one post pics of how- to swap cams i have mine but an waiting fo a dealer to install but if it is that easy i will do it
i have changed the head gasket on my 91 beretta 3.1 cant beharder then that
here is one sheet about camshafts
check this post, specifically chapters 5&6
here....for reference
Originally Posted by SS_SC_Cobalt
fo you guys doing this stuff here is a thanksgiving present..
Ch1 and 2
CH 3 and 4
CH 5 and 6
Enjoy!
Ch1 and 2
CH 3 and 4
CH 5 and 6
Enjoy!
Actually, on a 3.1 Beretta, I would take a head gasket job before a cam. Only because a cam on that car means jacking up the entire engine a little bit and sliding it out of the wheelwell, lol. I'm not really an organized person so I wouldn't be able to write out a how-to, but Im sure there is one if you were to google it or something. Maybe for the 2.2L and its the same concept really.
Dude dont waste 150 bucks on installation. DOHC Cams are SOOOO easy to install. I did an LS1 cam in one day, and thats OHV setup. The only PITA is keeping the timing, and even thats not very hard. And dont buy the tool, thats a waste as well, you can use other methods of keeping timing... Like a friend holding the gears while you swap the cams. Unless you feel thats worth 1/2 the cost of the cams themselves.
If you don't believe me, ask Fred @ SMG.
I never said anything about LS1 having overhead cams.
OHV = Overhead valve = cam-in-block
The LT5 (ZR1 'Vette) is DOHC. LS series engines (LS1,2,3,4,6,7) are OHV setups.
