Help me boost my 2.4L
Hey everyone,
I need help , I need a master list of everything I need to boost my 2.4,
I know this will seem long and repetitive, but I need the full master list,
so i can begin knocking down things on the list 1 by 1.
btw only performance mod: K&N SRI
Thanks guys!
Thanks guys!
Injectors, turbo mani , turbo ,turbo oil lines, wastegate depending on what turbo u get some have internal wastegates , bov charge piping , intercooler air to air or water to air if u go water to air then ull need and h/e and ic pump , down pipe , tune , wideband , interceptor , and boost gauge interceptor is nice for watching knock and iat's and missfires I think that's about it idk if I missed anything
Intake for turbo, your SRI isn't needed anymore
Turbo
Oil feed lines
Manifold
Exhaust
Charge pipes and intercooler
Bov or recirc valve
Larger injectors
Custom tune
Wastegate
Boost controller
Gauges to monitor oil pressure, boost, fuel pressure, knock retard etc.
Depending on your power goals you should also look into pistons, studs etc.
Turbo
Oil feed lines
Manifold
Exhaust
Bov or recirc valve
Larger injectors
Custom tune
Wastegate
Boost controller
mmcgee123. I plan on getting the same exact set up as you. Stage 2 kit with the injector upgrade & MBC. I got a question for you..What was the total cost for everything together? Did you install it or did they, who tuned it? I need to know what the total cost for the kit, any info would be nice, thanks..
http://www.zzperformance.com/cobalt_...s1.php?id=1165
Everything needed sold in a kit from zz performance 2.2 and 2.4L
Sl0wbaltSS
Nov 21, 2018 11:11 PM
