How do I ask the dealer to do a crank relearn
They arn't just going to do it cause you ask them to. They gonna get paid.
If you dont tell them what you didand try it under warranty, then they will most likely get the lastest software off Tis2Web and reflash you right back to stock.
How do I get the dealer to do it and not get in trouble. I don't mind paying a fee at all.
Just tell them you need a crank re-learn. Usually they won't ask any questions, but if they do just say you had to replace the pcm. Its not an un-common thing to have done. You'll fine.
A friend of mine is a mechanic (Not from the dealership). Says he can do it for the Cobalts with his scan tool.
"colbalts will work, its a standardized procedure with the updated scan too"
Which I guess means that any place can do it, Like Autozone/Canadian Tire...etc...
Anyways, he'll be doing it for me for free.
Heck my dashhawk can do it too. If anyone needs a case relearn that is from Sioux Falls South Dakota let me know. I don't think you should have to pay for that. Also if you want to go do some performance tests for your mods I would be glad to help out.
Nice!
if u know somebody who has a dashhawk.. with the new version they can do it for u.. or find somebody at a local tech college to do it for u.... i know all the local jr colleges and tech colleges around here have gm tech 2 with flashers
Jeff if you make an appointment at the dealer it took me 30 seconds for them to do. Just tell them you have a performance tune on your PCM (which is new to your car) and they can do the crank (case) learn on it. The tech hooked up and 30 seconds later it was done. The car will run without this done but this just sincs up all the sensors for timing, crank etc.
Can't wait
Whenever you flash your computer you need to do a case relearn.
GENERAL MOTORS VEHICLE COMPUTER RELEARN PROCEDURES
Performing any of the following repairs may require you to initiate a computer relearn procedure in order to restore proper vehicle operation.
Powertrain Control Computer replacement with a nontransferable PROM
Powertrain Control Computer reprogramming
Body Control Computer
Instrument Cluster replacement
Engine replacement
Crankshaft replacement
Crankshaft harmonic balancer replacement
Crankshaft position sensor replacement
Diesel Engine controller
Diesel engine PCM with or without injection pump replacement
Diesel engine front cover replacement.
Engine replacement
agentirons
Oct 16, 2015 02:11 AM
roth
Sep 26, 2015 12:16 PM
