how much of a difference will a...
Old Dec 14, 2009 | 11:41 PM
Dragonsfire12345's Avatar
How much of a difference will a 2 bar map sensor, and lsj throttle body do? I know with the 2 bar you can do alot more tuning, wise and of course the tb is bigger than the le5
Old Dec 14, 2009 | 11:45 PM
Maven's Avatar
Are you boosted? if not no need for a 2bar
Old Dec 14, 2009 | 11:53 PM
CordiaDOHC's Avatar
im not sure anyone on here knows about the throttle body to be honest. On a nearly stock vehicle Id think itd only help out response wise and maybe 1-2hp.
Old Dec 14, 2009 | 11:55 PM
glen229's Avatar
hes boosted, i picked up 2+whp from the ported and polished lsj when i was supercharged, it was about 12-15 in conjuction with the zzp midlenth and a zzp 3" intake also
Old Dec 15, 2009 | 05:43 PM
yup I'm boosted, guess I should've mentioned that in my op. Oh and I'm running a 2.8in pulley at 14psi
Old Dec 15, 2009 | 05:46 PM
slowswap's Avatar
Might as well run a 2.5 bar LSJ map so you monitor temps too.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
importkiller
Sep 30, 2015 07:18 PM
Sep 28, 2015 12:51 PM
