Injectors
Old Jan 26, 2010 | 11:04 PM
clayton182's Avatar
Injectors
Does anyone know of any good injectors to put in my 2.4 SS? or any help finding some? I would like my car to be quicker! and need some major help!!!
Old Jan 26, 2010 | 11:07 PM
scottyguy401's Avatar
I don't see upgrading injectors making your car faster, unless your stock injectors are maxed out
Old Jan 26, 2010 | 11:51 PM
clayton182's Avatar
any ideas that are semi cheap? i put a CAI on it but i cant really tell a difference
Old Jan 27, 2010 | 09:00 AM
wesg631's Avatar
I don't think injectors would do anything if you just have a cai, I don't even think a fully bolted and tuned 2.4l would need bigger injectors. If you want some find some cheap stock lsj ones and a harness out of an ecotech cavi or buy the ones from zzp but you would need a tune for them to work right
Old Jan 27, 2010 | 09:27 AM
Staged07SS's Avatar
Administrator
Administrator
i'll be selling my stock lsj injectors from my 07' SS/SC shortly. there is only 4400 miles on them. if you want to run larger injectors, you will need to tune for them.
Old Jan 27, 2010 | 09:55 AM
Illini_06SS's Avatar
Injectors do nothing for you for increased power. They just let you put more fuel into the cylinders. Without having a way of putting more air into the cylinders as well (forced induction, cams, head work, etc.) they'll just put the same amount of fuel into the cylinders as your old injectors did.
Old Feb 4, 2010 | 08:42 PM
hotpursuit's Avatar
you probably wont need injectors ever on n/a. as you lean the car out the IDC drops. unless your running like stage 3 cams or something, and for the le5 that's not an option
Old Feb 4, 2010 | 08:43 PM
glen229's Avatar
n/a you should run 80's
Old Feb 4, 2010 | 08:45 PM
hotpursuit's Avatar
LOL
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
