INJEN SRI installed
Old May 5, 2006 | 11:44 PM
avro206's Avatar
INJEN SRI installed
My first mod!
Much thanks to Jekyl for giving me a hand (hope you got all your tools back!) We just did the SRI cause I don't feel like taking my bumper off.
I will go back to the track as soon as it reopens (they are paving) and report back on any improvements.
It sounds very cool and loud. There is a tiny bog but other then that it feels more responsive.
Didn't disconnect the battery no CEL.
On the butt-dyno it does feel better but the track (or dyno) is where the real proof is.
Old May 5, 2006 | 11:50 PM
Jekyl's Avatar
woot!
i think you can hit 15s easy now ..with some good shifting
p.s. i think im gonna order a clutch tomaro...
Old May 6, 2006 | 02:25 AM
NJHK's Avatar
Cool.
Not fully sure if the 2.4s have IAT sensors or another type of sensor, but as long as the sensor that was in your original airbox is in your aftermarket one, you shouldn't have any codes.
Old May 6, 2006 | 07:24 AM
JohnyNFullEffect's Avatar
no need to take off the bumper. just take off your passenger front wheel and disconnect a few of te plastic plugs, then move your wheel well cover and it's right there!
Old May 6, 2006 | 07:54 AM
berndogz's Avatar
True
Just did it in my buddys 2.4L
He just took off the wheel well plastic cover and you have perfect access to everything.
Taking the bumper off would be nutz
Old May 6, 2006 | 08:11 AM
Woody's Avatar
AVRO,
I did my Injen Thursday. Also did short ram. If the Cobalt is like other cars you may loose like 1 hp from going short ram, but you gain throttle response. You reset the ecm right?
Good going.
- w
Old May 6, 2006 | 08:13 AM
avro206's Avatar
Originally Posted by Woody
AVRO,
Good going.
- w
uh negative on the ECM. Do I disconnect at the battery or can I disconnect in the engine bay?
Old May 6, 2006 | 08:46 AM
Woody's Avatar
AVRO,
I disconnected at the trunk. Not sure about the Cobalt, but with other cars I heard it is best to get the engine warmed up, then disconnect one lead (for 12-15 minutes, this is neccessary because of the retained power module) - then reconnect, and drive like a madman for about 20 to 30 minutes. If you have to re-set all your radio stations that is a good sign you did indeed reset.
I did not feel much if any bump until after I reset.
- w
Old May 6, 2006 | 10:07 AM
snowbred's Avatar
Avro, can you take a picture of your intake installed. No mattre how much i adjust mind it is still hitting that black metal part in the corner.
Old May 6, 2006 | 12:46 PM
Jekyl's Avatar
Avros is hitting it too. We just put some black tape around the black metal piece (used for lifting engine out of engine bay) so that the SRI could lean against it without getting scratched up.
Old May 6, 2006 | 10:08 PM
avro206's Avatar
AVRO,
- w
I too the scew off the positive cable and pulled but it did not budge. Is there a trick or do you really have to yank it?
Old May 6, 2006 | 10:50 PM
Woody's Avatar
Talking
I did the negative. It doesn't matter which terminal - you are just breaking the loop. There is a small 10mm nut that holds the negative terminal on. Loosen that until you can wiggle the terminal around on the battery post, and then it should lift off. Once you get it off, leave it disconnected for 12-15 minutes. Then tighten back on, and enjoy.
- w
Old May 6, 2006 | 10:55 PM
avro206's Avatar
thanks I'll give that a try--again. Perhaps I was not wiggling it correctly
Old May 6, 2006 | 11:13 PM
Woody's Avatar
Talking
You will be glad you did. I can not tell you how the positive (red) terminal is set up. I never even removed the red rubber cover to look at it.
Any time we do an engine/ecu/intake/exhaust mod - we should reset the ecu. In this way we "tell" the ecu our components have changed, and the ecu will re-calibrate to take advantage of the mod.
- w
Old May 7, 2006 | 12:00 AM
jrcobaltss's Avatar
hey hey avro/jekyl do u guys wanna help me install my Intake when i get it within the 2 weeks here haha in my Pursuit GT =D
Old May 7, 2006 | 12:22 PM
avro206's Avatar
I could lend a hand now that I have seen it done. Jeykl did most of the work Hardest part is getting that palstic piece that goes over the TB off.
Are you going SRI or CAI? What community in Calgary do you live?
But bring it out to Race City first! Then you can guage the actual effectiveness of the mod.
Old May 7, 2006 | 08:20 PM
Woody's Avatar
AVRO & Guys,
I had some time on my hands - I extended the Injen SRI to make it a CAI. I did it without removing the right front wheel - although in hind site that would have been a good idea, because I ended up jacking up the right front quarter anyway to get at some of the bolts/screws that held the plastic wheel well in there.
This kind of bleeds into another thread - but my butt meter says there may (only may) be more top end with the CAI, but I think I did loose some responsiveness, and maybe a little low end. I will probably go back to the SRI. Actually I'd like to take some measurements and see if I can come up with an intake that is half way between the SRI, and the CAI in length.
- w
Old May 7, 2006 | 08:54 PM
Nuclear's Avatar
injen does a good job with performance
Old May 7, 2006 | 09:35 PM
jrcobaltss's Avatar
Im just gonna get the SRI and i live in Chestermere.. its like 10min outside of calgary
Old May 7, 2006 | 11:32 PM
avro206's Avatar
you keep ing telling me and I keep forgetting that--doh. I have a friend that lives in Chestermere. It's pretty easy to do I just have to have the time to help ya.
Old May 7, 2006 | 11:56 PM
jrcobaltss's Avatar
Alright man cool cool, i gotta buy the thing first haha how much roughly did u pay? and from where?
Old May 8, 2006 | 03:19 AM
avro206's Avatar
Speed Tech racing. They are on 32nd ave NE. $350 taxes in. Injen shipped them the S/C intake (Speed Tech did order the correct part #) so it because of their mistake it took awhile.
Hopefully that will not happen to you.
Old May 8, 2006 | 11:47 AM
Jekyl's Avatar
Yeah speedtech is a distributor for Injen. They can get i for yeah. When i ordered mine though, I ordered from www.ptuning.com , they arent bad. And they have pretty good customer service.
Old May 8, 2006 | 09:07 PM
jrcobaltss's Avatar
350$ nice ill be picking that up here soon.. within the weeek
Old May 8, 2006 | 11:02 PM
avro206's Avatar
If your buying from Spedtech-they do not stock them but will place an order with Injen. It will take a few weeks.
dennis69
Oct 20, 2015 07:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
