lsj motor in a 2.4 ss!!!!!!!!!!!
i can get a whole motor for a damb good price i want to know how much of a pain it is to swap in a 2.4 ss or if its possible and what trans can i use can i use my stock trans ???
***plz do not answer this tread if u have no clue what your talkin about i need real help *** thanks
tranmission is different
wiring harness and sensors are different
ecm/bcm is different
axles, hubs are different
not to mention all the additional supercharging parts required, like tuning, heat exchanger, rad hose, windshield washer bottle, intake, etc
There is a guy here in Houston that succesfully swapped a lnf into a lsj, but that was a full transplant, dropped the cradle swapped it in and replaced everything from the trunk to the bumper, he had a donor car and thats basically what you need, every single part. You can attempt to find the rest, but I willing to bet if you sell it for profit thats a nice start on a 2.4 boost build.
Good luck.
hey guys yea im getting a whole motor with *0* miles on it lol thats why i was wondering yea i probly could just sellin it and boost the car back to were it was !!!! probly be my best bet cuz i dont feel like doin a bunch of all that stuff to it and spending worthless money just to convert it but it deff would be tight to see a lsj in a 2.4
Why? Keep the VVT, more power potential. The VVT motors have a different design to the head gasket and extra oil passages going to the head that would have to be blocked to run a non VVT head anyway. Ported 2.4 head with upgraded springs and maybe some turbo cams would be the best way to go for sure. There's nothing special about a stock 2.0 head anyway.
There are a few people running a 2.4 bottom end with a 2.2 head with either the stock LE5 head gasket or a 89mm Cometic 2.2 head gasket.
No cam Phasersr running down the side and more cam options vvt is good but if u wanna make big power I'd go 2.2 or 2.0 head cus at some point ur gonna need a better cam and zzp is really the only option or a custom grind but have fun degreeing / timing a cam correctly that hasn't had extensive r&d
ThoR294
Oct 4, 2015 08:44 PM
