lsj motor in a 2.4 ss!!!!!!!!!!!
Old Jun 12, 2011 | 11:20 PM
cobaltss76's Avatar
i can get a whole motor for a damb good price i want to know how much of a pain it is to swap in a 2.4 ss or if its possible and what trans can i use can i use my stock trans ???
***plz do not answer this tread if u have no clue what your talkin about i need real help *** thanks
Old Jun 12, 2011 | 11:30 PM
07BoostedG5's Avatar
if you have to ask its going to be difficult.
you need all the wiring and ecm/tcm/pcm to make it easier
and no the trans will not bolt up (if I recall)
Old Jun 12, 2011 | 11:44 PM
cobaltss76's Avatar
(if i ask a question its automaticly difficult???) yea well it might be difficult but reward is worth it if i can get it done some how
Old Jun 13, 2011 | 12:59 AM
noorj's Avatar
better off buying a ss/sc
Old Jun 13, 2011 | 01:01 AM
JustACobalt's Avatar
buy motor for "damn good price" -> sell motor for more than you bought it for -> save up on a turbo kit for your 2.4, done.
Old Jun 13, 2011 | 01:02 AM
redcobalt07's Avatar
The trans won't bolt up at all. The motor would physically fit but you'd need to replace almost every sensor in the car to make it even possible.
Old Jun 13, 2011 | 07:49 AM
07cobalt_LT's Avatar
tranmission is different
wiring harness and sensors are different
ecm/bcm is different
axles, hubs are different
not to mention all the additional supercharging parts required, like tuning, heat exchanger, rad hose, windshield washer bottle, intake, etc
Old Jun 13, 2011 | 08:02 AM
cmatthewb101's Avatar
Why not just pull the parts off, and SC the 2.4? Would be alot less parts, and headache
Old Jun 13, 2011 | 08:03 AM
Im not trying to offend, all Im saying is if you have to ask then you most likely dont have the know how and it will be very difiuclt for you, in other words I assume you have no idea what your doing.
There is a guy here in Houston that succesfully swapped a lnf into a lsj, but that was a full transplant, dropped the cradle swapped it in and replaced everything from the trunk to the bumper, he had a donor car and thats basically what you need, every single part. You can attempt to find the rest, but I willing to bet if you sell it for profit thats a nice start on a 2.4 boost build.
Good luck.
Old Jun 13, 2011 | 08:23 AM
ItalianJoe1's Avatar
Build/boost the 2.4, will be much easier for you.
Old Jun 13, 2011 | 09:18 AM
cobaltss76's Avatar
hey guys yea im getting a whole motor with *0* miles on it lol thats why i was wondering yea i probly could just sellin it and boost the car back to were it was !!!! probly be my best bet cuz i dont feel like doin a bunch of all that stuff to it and spending worthless money just to convert it but it deff would be tight to see a lsj in a 2.4
Old Jun 13, 2011 | 09:19 AM
cobaltss76's Avatar
yea ive already done that to this car and sold motor/turbo kit together to put my other stock otor back in i made 348whp i just didnt want to spend to much again
Old Jun 13, 2011 | 01:36 PM
mmcgee123's Avatar
Built 2.4 bottom end 2.0 head with cams + turbo kit
Old Jun 13, 2011 | 01:37 PM
^ there ya go!
Old Jun 13, 2011 | 01:44 PM
Why? Keep the VVT, more power potential. The VVT motors have a different design to the head gasket and extra oil passages going to the head that would have to be blocked to run a non VVT head anyway. Ported 2.4 head with upgraded springs and maybe some turbo cams would be the best way to go for sure. There's nothing special about a stock 2.0 head anyway.
Old Jun 13, 2011 | 01:57 PM
mmcgee123's Avatar
Way more cam options for the 2.0 head then 2.4
Old Jun 13, 2011 | 02:25 PM
newt's Avatar
Nope, any Ecotec varriant head gasket will work for using a 2.4LE5 bottom end with any combination of heads.
There are a few people running a 2.4 bottom end with a 2.2 head with either the stock LE5 head gasket or a 89mm Cometic 2.2 head gasket.
Old Jun 13, 2011 | 03:41 PM
cobaltss76's Avatar
yea how much of a diff is the 2.0 head on a 2.4
Old Jun 13, 2011 | 06:37 PM
OttawaMark's Avatar
Why a 2.2 head?
Old Jun 13, 2011 | 07:30 PM
newt's Avatar
These swaps where in J-Bodies, which came with a 2.2.
Which is the reason for the 2.2 head on the 2.4 block.
Old Jun 13, 2011 | 07:45 PM
mmcgee123's Avatar
No cam Phasersr running down the side and more cam options vvt is good but if u wanna make big power I'd go 2.2 or 2.0 head cus at some point ur gonna need a better cam and zzp is really the only option or a custom grind but have fun degreeing / timing a cam correctly that hasn't had extensive r&d
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
Stuff
Oct 1, 2015 05:47 PM
