M62 Build
Old Jun 8, 2012 | 07:19 AM
klotzy_550's Avatar
M62 Build
Well after lurking around CSS for the past three years and "gathering information" it is official that I am doing a M62 build on my 08 2.4. I will try my best to post pictures of my progress, no promises though. Currently I am cleaning everything up and painting it, also I had my endplate drilled and tapped for dual pass "Poor man's version"
Here is some of my stuff at the moment:
Hopefully I can start installing parts on the engine next week sometime.
Old Jun 8, 2012 | 07:53 AM
hhrfreek's Avatar
Cool have fun.
What pulley, fuel inj, he, exhaust is going to be in your setup?
Old Jun 8, 2012 | 08:13 AM
klotzy_550's Avatar
Originally Posted by hhrfreek
Cool have fun.
3.06" Pulley, Siemens 60#'s, Cobra Heat exchanger, I already have a Vibrant Cat back, and LSJ Manifold, For Downpipe Im fabbing my own
Old Jun 8, 2012 | 08:33 AM
Staged07SS's Avatar
Administrator
Administrator
Nice work cleaning everything up.
Looks good.
Old Jun 8, 2012 | 08:45 AM
2009CobaltLT's Avatar
Is it just me or is that dual pass fitting going to have a problem...
Old Jun 8, 2012 | 09:05 AM
klotzy_550's Avatar
Thats just a test fitting, to make sure the threads were right. I will be putting a 90 degree fitting in there.
Old Jun 8, 2012 | 09:48 AM
Oh gotcha, just checking
Old Jun 9, 2012 | 06:12 PM
klotzy_550's Avatar
Alright a little update, as of today I received my injectors, maf extension, gaskets, 6-8pin throttle body harness, upper radiator hose. Stilling waiting on my 2.5 bar tmap sensor, heat exchanger, and intake. All of which should be here by Tuesday
Old Jun 26, 2012 | 07:23 AM
klotzy_550's Avatar
Well another update: I am making some good progress hoping to finish up by the end of the week. My EZ-Flash cable arrives friday
Old Jun 26, 2012 | 07:27 AM
klotzy_550's Avatar
BTW I know in Beck's build he stated that the lower intake manifold mount bracket needs to be bored out to 8MM, on mine I had to bore it over to 10MM, and the two bolts that thread into the engine block are M10x55x1.50.
Old Jun 26, 2012 | 07:18 PM
nhanson's Avatar
I didnt use the lower mount. Ill get you bolt size when im home
Old Jun 27, 2012 | 07:37 AM
klotzy_550's Avatar
Progress...
Old Jun 28, 2012 | 11:07 PM
nhanson's Avatar
Looks like good progress!
Old Jul 12, 2012 | 10:00 AM
klotzy_550's Avatar
Well its all together and running, been babying it alot for now to break the blower in a bit, and to get some logs for daily driving. Ill see if I can get some vids of power runs in the next couple days. Also its pretty neat to hear the slightly altered exhaust note
Old Jul 19, 2012 | 11:09 AM
klotzy_550's Avatar
And the Promised video, I ran 35-75 so I didnt burn out lol
35-75mph Pull - YouTube
Old Jul 22, 2012 | 03:02 PM
Mindrot's Avatar
Love the valve cover. Do the same color for the fuel rail man
Old Jul 22, 2012 | 03:15 PM
klotzy_550's Avatar
Haha thanks I did it on my own at school, I think I'm going to design up a cool fuel rail cover on UGnX and water jet it out in aluminum and then powder coat that.
Old Jul 22, 2012 | 06:13 PM
Mindrot's Avatar
Where would it be mounted? Only mount points are at where the valve cover is secured and where the fuel rail is secured.
Old Jul 27, 2012 | 04:59 PM
klotzy_550's Avatar
I suppose I willhave to decide when I actually start designing the part, I could either make a bracket that runs accross from where the fuel rail bolts on and just have two holes tapped on said bracket and design my cover to mount to that, or I could just have it mount to the fuel rail bolts too, because my thoughts are if Im taking the cover off Im probably going to be working with the injectors/fuel rail, or blower anyways.
Old Jul 28, 2012 | 11:28 AM
HHR Panel Man's Avatar
Looks good.
I will be starting my 2.4 M-62 build soon, auto trans tho. I got the last $300.00 in parts sitting in my ZZP cart just waiting to get that cash up to buy them.
Yours in a manual trans and a Cobalt? What tuning did you do?
I'm doing my HHR 2LT Panel, I was thinking on starting a Thread and posting a bunch of pics of the parts I have been slowly buying over the last 14 months.
Anyways Nice looking and sounding install, just wanted to post and follow along.
Thanks
Old Jul 28, 2012 | 02:21 PM
olivecj's Avatar
Originally Posted by HHR Panel Man
Looks good.
Thanks
You can tell hes auto, so hp or trifecta is who you'll need to be tuned by.
Old Jul 28, 2012 | 02:24 PM
olivecj's Avatar
car sounds really good man. what other supporting mods do you have?
Old Jul 29, 2012 | 07:22 PM
klotzy_550's Avatar
All I really had was a vibrant cat back that carried over from NA to SC, I do enjoy the cars tone a lot and I took it for an extended drive yesterday and averaged 39mpg (calculated). I have a CAI on my SC'd build now too. Yes it is an auto, and just a couple tips: 1) before you bolt the blower down , set it on the manifold and mark out where the pulley is with a sharpie and cut that metal out with a cut off tool, that way you can put a belt on with out removing your blower and if you don't when u brake hard it will rub and make a terrible noise. 2) USE a relay when installing the intercooler pump, otherwise you risk throwing a P1681 cel. If you need any help along the way you can just ask me or pm me for my phone number.
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
goaliemo
Sep 28, 2015 01:37 PM
