maf issue?
Old Nov 10, 2012 | 01:41 PM
Ardy's Avatar
maf issue?
I've gotten a code for lean/rich engine conditions. Recently I unplugged the maf and noticed no difference, the car ran essentially the same.
Is that a wiring issue or is it time for a new maf?
Old Nov 10, 2012 | 02:36 PM
06Cobalt2.4's Avatar
Which code are you pulling?
Old Nov 10, 2012 | 02:38 PM
nhanson's Avatar
Code numbers please.
Take it out and spray it down with cleaner.
Could be other things like a vac leak maybe?
Old Nov 10, 2012 | 03:24 PM
Ardy's Avatar
Already cleaned it. I think it was p1174.
There should be some sort of difference when I unplug it though, no? It used yo stall when I unplugged.
Old Nov 10, 2012 | 03:51 PM
nhanson's Avatar
I googled and came up with to check your O2 sensor if thats the correct code.
Old Nov 10, 2012 | 04:30 PM
Ardy's Avatar
Yeah it's p1174, that said though I feleted it a while back and it hasn't come back on. On a note I took it for a test drive today without maf hooked up and I noyiced no difference.
Old Nov 10, 2012 | 04:45 PM
08G5GT2.4L's Avatar
plug the maf back in, the code isnt related to the maf.
possible cause https://www.cobaltss.net/forums/2-4l...s-lean-217194/
Old Nov 11, 2012 | 04:09 PM
Ardy's Avatar
Awesome - okay.
That said though, if I understand my car at ALL it shoudl NOT run the same without the MAF plugged in.
If so - why do the cars have one in the first place? LOL
So I guess to make this simple, we'll have two questions.
1) Do I have a MAF issue? Car runs the same with/without MAF plugged in.
2) P1174 - is there any easy way to check to see if my car is running lean/rich? This code pops up once in a while, but only once in a while.
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
yellow dragon
Sep 28, 2015 09:49 PM
