MAF problem
Old Jan 7, 2008 | 02:44 AM
jdub777's Avatar
MAF problem
SJSchafer was tuning my car when we came across this problem.
"Update...
Well, he came over and I was able to dial in some things to get hit running a bit better. The problem we had was that he came over with a CEL that came on when he installed his Injen intake. I scanned it and it wasn't a lean code, like I expected, but a MAF failed code. The MAF hz are reading 0 all the time. I reset the ECM and set the DTC to no error reported and his car wouldn't idle at all. Still 0 on the MAF. All I can think of is a screwed MAF sensor. Any ideas? By the way, with the MAF unplugged and the key in run, I get 12v to the center pin on the plug and 5v to the end pin (don't remember the color)."
Old Jan 7, 2008 | 09:54 AM
iLLmaTic3s's Avatar
so the cel was already on and was caused by the intake...injen use a oiled filter..i woulndt doubt that fucked up ur maf
Old Jan 7, 2008 | 10:16 AM
Kaisoboy's Avatar
Is the MAF installed in the right direction? If it is then check the fuses. Sometimes they are not seated right or installed in the right pins but I guess you said you are geting 12 V. If it is not either of these then yes I would think that the MAF sensor is hooped and needs replacement. You could also try cleaning it also.
cheers
Old Jan 7, 2008 | 02:44 PM
jdub777's Avatar
cheers
ya the first thing we did was clean it, and we made sure it was in the right way. I think it needs to be replaced.
Old Jan 7, 2008 | 02:54 PM
Kaisoboy's Avatar
That sounds like what needs to be done.
Hope yah get it figured out.
Old Jan 7, 2008 | 02:59 PM
blu3_v1p3r's Avatar
When I put in my GMPP intake, i had gotten a MAF code. My car still idled right, and and response was good and it went out after about ten minutes, them when we scanned it again it was fine. I know this was know help to you guys, but good luck.
Old Jan 8, 2008 | 09:20 AM
iLLmaTic3s's Avatar
let us know how it turns out
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
