N/A 2.4 HP/TQ potentials?
Old Jun 15, 2006 | 07:08 PM
jaslowyota's Avatar
Originally Posted by Gory
Interesting considering that lotus was one of the co designers of the ecotec and they use almost exclusivly toyota stuff hmmm.
I didn't think lotus messed with motors? I thought the motor's in the elise and exige where toyota motors reworked by yamaha with an yamaha transmisson?
Old Jun 15, 2006 | 07:09 PM
joeworkstoohard's Avatar
well GM has a lot to do with a lot of car makers. people do not give them enough credit for the technology they produce.
Old Jun 15, 2006 | 07:32 PM
Gory's Avatar
Yah good point if you look http://en.wikipedia.org/wiki/Chevrolet_Cobalt_SSand here
http://en.wikipedia.org/wiki/GM_Family_II_engine#Ecotec
http://en.wikipedia.org/wiki/GM_Delta_platform
http://www.grouplotus.com/mediactr/p...ad.php?pid=242
Old Jun 15, 2006 | 07:40 PM
i wonder how they made the block stronger? the old toyota 4A-GEs had more ribbing and better metal... interesting.
Old Jun 16, 2006 | 12:19 AM
NJHK's Avatar
it's hard to come by but here's a few "what it looks like to me"
the VVT system looks alarmingly like the VVTi system used by toyota, wouldn't surprise me based on thier close dealings
the 2,4 seems to be a bored over version of the 2.2 block wise. since it' snot a HUGE increase in displacment, i'd guess that it was done to match up with the much wider valve spacing that the VVT's SEEM to have on toyotas
the head is way different. the cams have larger lobes on similar engines and the timing changes a lot. if you look at a lot of dyno sheets the 2,4 seems to make less power than the 2.2 at low RPM. i assume this is to smooth out the idle.
Correct. This form of VVT changes lobe profiles according to oil pressure which is controlled by the computer.
Old Jun 23, 2006 | 03:07 PM
Sorryociffer's Avatar
Originally Posted by avro206
I would think the untapped power lies in the cams and head work. Maybe getting that compression ratio up to 11:1--might need custom pistons. Stroking would be prohibatively exspensive......a custom crank and rods.
GM did not go aggresive at all with this engine.
Lets not forget lighter internal parts. Less friction and weight can do BIG things for an engine. Not only more power but a faster responding engine and if you can keep your foot out of it, more MPG.
S.O.
Old Jun 23, 2006 | 03:13 PM
Originally Posted by jaslowyota
damn, 14:1 is what my bike has, if it were me i would go with 12:1 if its an daily driver you wouldnt have any problems.
Even 12:1 is pretty high, would require 93 octane regulary. Anything higher and it requires some exotic valvetrain/head design work to keep detonation away and valve clearance good and would require 93 octane at a MINIMUM.
S.O.
Old Jun 23, 2006 | 03:40 PM
Asphalt Assault's Avatar
Originally Posted by HiSpdPursuit
I've decided that im going to probably keep my 2.4 as N/A. The most i think i would use is a Supercharger...turbo is too complicated and $$$ right now
anyway i wanted to get some opinions on how much HP and torque you can really squeeze out of the 2.4L VVT. I know the basic bolt ons like CAI, cat-back, and header.
what i am really interested in is really digging into the motor itself. Ie. Full port and polish of the head, camshafts, and is it possible to bore over and possibly stroke the 2.4L without having to re-engineer the computer?
can you change the camshaft's lobes and the crankshaft stroke without messing up the VVT and the PCM? Frankly this new technology is complicated...im used to my old 5.0L and bored and stroked pushrod engines.
all I can say is get a s/c from one and intake from gm or a wrecker. then hptune it. Need injectors? by the stage two injectors from someone going to 60lbs set.
you will want to make sure HPTUNER set up will work with PCM
Old Jun 24, 2006 | 06:30 AM
HiSpdPursuit's Avatar
it is possible only if HPTUNERS can get it to work with these PCM's and the VERY limited BAR MAP info
GaryGibblez
Jan 14, 2020 10:35 AM
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
