oil leak
Old Mar 16, 2008 | 12:00 AM
cruisn's Avatar
oil leak
Has anyone else have an oil leak issue around the oil filter cap and oil cooler setup on the 2006 2.4? Mine is leaking, not bad, but is slowly getting worse. The oil cap is tight and still has a good gasket in it. I have no clue? any ideas? ever have this happen?
Old Mar 16, 2008 | 01:27 AM
iLLmaTic3s's Avatar
never had this problem..really odd ..did u put in too much oil? check ur dipstick
Old Mar 16, 2008 | 01:29 AM
Red2.4SS's Avatar
I don't think 2.4L have an oil cooler. But if you filter cap is leaking then you probably need a replacement.
http://www.crateenginedepot.com/stor...P1674C193.aspx
Old Mar 16, 2008 | 01:32 AM
cruisn's Avatar
figured, it still has a decent seal but who knows at 40 or so psi right. oil is fine. I check it all the time.
oil cooler is right beside the oil filterto the right. the chunk of aluminum with the coolant lines
Old Mar 16, 2008 | 01:34 AM
Red2.4SS's Avatar
Dont have one. I feel gyped!
Old Mar 16, 2008 | 01:41 AM
cruisn's Avatar
you should it is right by the oil filter and above the tranny
Old Mar 16, 2008 | 01:43 AM
Red2.4SS's Avatar
yeah I don't have one. I've seen em on the SS/SC's
I wan't one!
Old Mar 16, 2008 | 01:46 AM
cruisn's Avatar
wierd...
Old Mar 16, 2008 | 01:49 AM
Red2.4SS's Avatar
Yeah, I'm real jealous now!
I didn't even know the 2.4L had them!
My turbo is drooling over it!
Old Mar 16, 2008 | 01:54 AM
cruisn's Avatar
lol, go figure
Old Mar 16, 2008 | 11:23 AM
Viper33884's Avatar
Is yours an auto? If so then that's the pump.... The 2.4's don't have an oil cooler trust me....take a pic and I bet it's the pump for the hydraulics for the auto tranny. Has like 5 lines I think about 1/8" black.
Old Mar 16, 2008 | 01:59 PM
cruisn's Avatar
I have a 5 speed
Old Mar 17, 2008 | 08:35 AM
css9450's Avatar
Oil coolers were eliminated midway through the 2006 model year. I've seen them both ways and checked the build dates; its always the later ones that don't have the cooler.
Old Mar 17, 2008 | 11:19 AM
Viper33884's Avatar
And I damn sure stand corrected, just don't see the point of an oil cooler in such a small engine.
Old Mar 17, 2008 | 04:32 PM
silentgarth's Avatar
When I had my engine replaced the new one had to be tap to take the old oil cooler
Check out mid paragraph:
Old Mar 17, 2008 | 05:16 PM
celicacobalt's Avatar
yes early 2.4's have oil coolers till the bean counters found out we dont need them in stock form.
Old Mar 17, 2008 | 08:38 PM
cruisn's Avatar
mine is an early 06 then. lol
Old Mar 17, 2008 | 08:43 PM
TheDriver!'s Avatar
No leaky leak here..
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
