P0107 Troubles
Old Jun 16, 2010 | 10:19 PM
synergy91's Avatar
P0107 Troubles
I've had this check engine light code on for awhile, and haven't really noticed any major performance issues but it's really starting to bother me.
So when this light came on the first time, I found it was:
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
So I went and got a new MAP sensor, replaced it, but the light stayed on. And has been on for over a month now without ever turning off.
I know this code is a major problem among the 2.0's but I can't really find much about this problem in the 2.4s. I have no engine mods except for a K & N drop in air filter.
What else could be setting it off. Also, when I plug my OBDII reader in it won't let me clear this code, It lets me clear any other code but for some reason this one just won't go away.
Old Jun 16, 2010 | 10:23 PM
DoMiStIc_RuSh_06's Avatar
Did you try unhooking the battery for a few mins then re hooking it up
Old Jun 16, 2010 | 10:46 PM
synergy91's Avatar
Yeah Ive tried that, it will turn the CEL off for maybe 30 seconds, but then comes back on with the same code
Old Jun 28, 2010 | 09:24 PM
synergy91's Avatar
Bump with update.
I haven't found a fix for this code, and now two new codes are in the mix
p0068 and p1682
P0068 - Throttle Body Airflow Performance ECM, PCM
P1682 - Ignition 1 Switch Circuit 2 ECM, PCM
I don't know if these 3 codes are somehow linked, and I'm basically a complete newb with most car engine stuff, but I want to learn. Can anybody shed some light on the situation for me?
Old Jul 2, 2010 | 11:11 PM
berto279's Avatar
i had that same P0107 code in my car and it was basically on all year long til i had to get it inspected. So i tried replacing my MAF didn't work, then i replaced both O2s, went away for three drives came back on. so i finally take it to the stealership and i find out all i had was a pin hole in one of my lines that was letting that little bit of air in to throw the code. so what im trying to say is i would have never found that out and would have just kept wasting money if i didnt take it to the dealership, i know its not what u wanna hear but the bill from my dealer ended up being less that the new MAF and O2s THAT I DIDNT NEED!
WhineSSbaby
Sep 1, 2020 12:39 PM
Bluelightning
Nov 11, 2015 02:41 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
Jeffwills14
Sep 6, 2015 06:52 PM
frost3
Aug 31, 2015 08:21 PM
