pipe size
Old Jan 4, 2006 | 09:27 AM
nomoreavril's Avatar
pipe size
is the exhaust pipe size 2.5 or 2.25 or 1.75 like the base..i have a catback on my base thats 2.25 and i could just put it on the 2.4 if i get it
Old Jan 4, 2006 | 09:30 AM
R33P3R007's Avatar
360 L337 User
it is 2.25 on the 2.4 i believe. not positive. but i think it is the same as the 2.0
Old Jan 4, 2006 | 10:00 AM
so its pretty much already got a catback exhaust except for the muffler right? only change would be the header?
Old Jan 4, 2006 | 10:05 AM
R33P3R007's Avatar
360 L337 User
yup, technically. but they make other ones for the 2.4 that are 2.5" and 3" custom ones
Old Jan 4, 2006 | 10:11 AM
celicacobalt's Avatar
my corsa is 2.5 and is a nice improvement, but yeah the 2.4 and 2.0 both come with a factory tuned exhaust changing the muffler would be fine for a small increase
Old Jan 4, 2006 | 12:07 PM
Dragonsfire12345's Avatar
thats what I did just changed the muffler, maybe later I'll go with 2.5 in. For sure I'm gonna get a Hi-Flow Cat.
Old Jan 4, 2006 | 01:53 PM
Brandon97Z's Avatar
Anybody else sure on the pipe size. I was always under the impression the the 2.4 and 2.0 got 2.5.
Old Jan 4, 2006 | 03:07 PM
i measured my stock 2.4 pipe at 2 inches i think
Old Jan 4, 2006 | 03:14 PM
SuperchargedSS's Avatar
I was quickly checking the site and had a good laugh at the post name "Pipe Size".... If this post would have had the *NWS* tag , I was not opening, end of story !!!!
Old Jan 4, 2006 | 10:11 PM
Its 2 1/4 Cuz When I Was At The Muffler Shop The Muffler Mounted Right On The Pipe And Its Inlet And Outlet Are 2.25
Old Jan 5, 2006 | 09:18 AM
korax123's Avatar
If it's like the SS/Sc and Ion RL are pipes are 2.5" up until the rear suspension and then they made it 2.25" a lot of people just step up the 2.25 to 2.5
Old Jan 5, 2006 | 09:24 AM
R33P3R007's Avatar
360 L337 User
Korax.. how loud is your 3 inch. i was thinking of getting the vbrant setup, but is three inch going to be too loud
Old Jan 5, 2006 | 11:28 AM
korax123's Avatar
It's not bad driving around town...but it drones pretty bad at 70+mph cause the speed limit here is 75mph. It's pretty deep sounding also. If you want a quiet muffler and have a nicer sound only when flooring it I would get a hi-flow chambered muffler. It would be as good as a straight through one but it wouldn't drone on the highway.
Old Jan 5, 2006 | 02:35 PM
i had a custom 2.25 flowmaster exhaust with a longer resonator, before i put the catback on the and just had the muffler, it droned bad from like 3k rpms to about 4 or so .....put i put the whole exhaust and longer resonator, didnt make it any louder but a lot deeper and it didnt drone at all
Old Jan 5, 2006 | 03:29 PM
Brandon97Z's Avatar
Thats what i was thinking it was. Looks like i'll just be replacing that 2.25 portion with 2.5 and a muffler. Thanks guys
Old Jan 5, 2006 | 03:59 PM
pclear9061's Avatar
yes it should be just like the ss/sc / RL in that it is all 2.5 until the back 1/4 where it drops to 2.25.
the setup that im selling right now is perfect. replaced the over the axle part with 2.5 and then have a 2.5 magnaflow muffler and IMO has no drone periods. its beautiful and when you down shift or left it engine brake ........ OMG its just a beautiful deep mean sound
Old Feb 7, 2006 | 08:30 AM
brentil's Avatar
The Solstice comes with 2.5" piping all the way back. It's one of the improvements the car has over the various other 2.4L VVT based cars that helps it have a higher rated HP value. Unless you're planning on producing well over 300HP the 2.5" pipe sizing is more then enough according to several of the supporting vendors at the solstice forum. Some have tried 3" piping and seen a very small increase in power over 2.5" but at a much larger cost and a much greater increase in 'raspy' sounding exhaust note.
Old Feb 7, 2006 | 08:36 AM
TimDang's Avatar
So the base cars have 1.75 the whole way back or does it change like the SS? I'm gonna do a 2.5 catback made at my local muffler shop, what kinda magnaflow are you guys using? And what length resonator or stock? Part # on 2.5" magnaflow plz?
Old Feb 7, 2006 | 11:53 PM
jerryg's Avatar
in my opinion i would not go for the 2.5 piping and the high flow cat unless we can get some good tuning. i have 2.5 piping with a 2.5 high flow cat from my header to resonator and my car has been parked for three days. im having some major problems high flow eficiency and maf sensor lighs coming on. to much air flow going in and to much out. i would just replace the mufler and leave the rest of the exhaust alone. just my opinion
Old Feb 12, 2006 | 06:42 PM
Hammer's Avatar
Selling this upgrade are you? How 'bout posting some info...
-Hammer
Old Feb 12, 2006 | 07:09 PM
sethallen's Avatar
should probably know this by know, but what do u guys mean by "droning"??? thanks!
hacadacalopolis
Oct 28, 2015 06:09 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
