problems
Old Jun 7, 2009 | 05:59 PM
rockstar014's Avatar
problems
ok guys need some help wickedss was gonna put the tune on and the car would not take the tune it wouldnt even star what might be this prob??
Old Jun 7, 2009 | 10:52 PM
mbucky01's Avatar
hmmm im not sure but those rims are BA
Old Jun 7, 2009 | 10:53 PM
Matt M's Avatar
2.4 auto or manual?
Old Jun 7, 2009 | 10:55 PM
mbucky01's Avatar
Originally Posted by Matt M
2.4 auto or manual?
ill answer that for him its 2.4 auto
Old Jun 7, 2009 | 11:00 PM
ya its a auto i mean the first tune he put on it worked but when he did the fuel tables for the 42.5s its wouldnt even start it would sputer
Old Jun 7, 2009 | 11:29 PM
Matt M's Avatar
Ok, so you mean the car literally wouldn't start. I thought you meant that the tune wouldn't start to flash. I was going to say to try a full write because the 2.4 autos don't like to take a partial write.
Did you check to make sure all of the injectors are plugged in? Check the injector harness and main harness for bent pins where they connect together.
Old Jun 8, 2009 | 04:23 AM
ok ill check in that also do u think anything would be wrong like with the wireing of the tb area?? im running the lsj one
Old Jun 8, 2009 | 09:48 AM
Matt M's Avatar
Was it already running the LSJ TB fine before you had issues?
Old Jun 8, 2009 | 11:18 AM
hoffa's Avatar
when the tuning was done... anything changed voltage wise?
something to do w/ the amount of volts going to the coils (or something like that), may have blown one of the huge buss fuses.... that's assuming that this area was changed.
when i was tuned years ago, this was done and it took us 3 hours to get it figured out and get the car started.
Old Jun 8, 2009 | 12:09 PM
well ya the tb worked when we put the lousy tune on it when we put the good tune on it it would not start then it went to lock mode for awhile then after that he flashed and put the old tune back on it then it started but it is running like ****
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
