PSI limits on the 2.4
well i was just sitting here thinking and i was wondering how much psi do you all think the 2.4 can handle?....im probabaly going to do about 10 as thats what my wastegate is(.7 bar)....so the question is what do you all think the 2.4 can handle safely.....discuss
psi doesn't have anything to do with how much a motor can take
that t3/t4 turbo you have is gonna flow alot more air than a T28 at the same psi. as far as how much power you can make on a 2.4, I would say as long as you're under 300whp you are fine from what I've seen so far.
exacly ionninja..but to give u a estamte cuz i know what ur thinking..id say 9-10 is good..we have very high compression and unless you plan to change ur pistions out..9-10 is safe..i know people on here run higher..but for me..9-10 would be enough psi..
ALSO depeneds what kinda turbo your running...lot of factors go into it
From personal experience, a certain turboed 2.4L ran quite well on 12psi boost. That car put a grin on my face for the longest time.
i think hahn has reached over 400whp on stock engine if that means anything, its all in tuning and supporting parts. Suppossedly the LE5 is a stronger engine than the srt-4's in stock form.
well i know that im just putting it that way so everyone else knows what im talking about...i know it all has to do with the fcm rates on the blower and what not...i dont think that 10 psi will be maxing the blower out or anything serious....should be pretty efficient...and im planning for about 300hp
I will say that more than 10psi starts to get nuts with this car. I assume you have 42# fuel injectors?
I think you're fine with 8-10psi as a starting point for this motor and a manual trans. The only reason I ran 8psi max (after testing a few boost levels, low AND very high) was because of the auto trans. Hahn ran up to over 14psi IIRC. Although, they (and everyone else) don't recommend running that for long without building the motor.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Iceberg
Sep 29, 2015 12:33 PM
