pulse plugs
Old Feb 10, 2008 | 03:34 PM
BigEMU1's Avatar
Originally Posted by CSM Huber
As an "old school" mechanic, I too have to wonder about the heat range of the plug, if its a "projected tip" type, and the "gap". For high RPM firing of the plug in a forced induction or high compression engine, some performance gains (lower 1/4 milw elapsed time) can achieved by dropping a heat range or two and dropping the spark gap by .010 or .015 inch. With a smaller spark gap, the break down voltage occurs sooner, effectively advancing the spark.
Are you reading these plugs?
Well I just read specifically on their website that it is absolutely NOT intended for Forced Induction, N20, or cars with modified internals, but is perfect for N/A's with bolt-on's.
I thought it was the other way around. You want to test the plug to operate with the highest gap possible for performance. Someone correct me if I'm wrong.
Would an N/A 2.4L with modified internals see benefit from a plug that is a step colder? Let's say I/H/E/TB/Inj/Cams/Tune. I'm thinking there would be more leeway in tuneability with a step colder, even N/A?
Old Sep 7, 2009 | 04:17 PM
sanchez's Avatar
bump any new news on these plugs
Old Sep 7, 2009 | 04:22 PM
berto's Avatar
These are good plugs
i had em on my old lsj
and i really felt the difference in power...good buy
Old Sep 7, 2009 | 04:44 PM
steddy2112's Avatar
These plugs are the biggest ******* scam ever.
Old Sep 7, 2009 | 04:52 PM
09cobaltsc's Avatar
they arnt a scam my buddy has them in his 05 ls and we both went to the dyno and my 09 bases 157 at the wheels his 160 at the wheels few extra horses. my 09 has 2k miles his has 36k
Old Sep 7, 2009 | 05:17 PM
CordiaDOHC's Avatar
That doesnt mean anything. Thats typical difference between stock cars... It could also be because his car has loosened up while yours still a bit tight still from the factory.
Old Sep 8, 2009 | 07:45 PM
09cobaltsc's Avatar
ill do mine and we will c where we are at
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
