pumped for the new setup this week
okay guys, this week im gonna be done with my new setup
this new setup consists of:
2.8 pulley
60's
snow performance boost/maf meth kit
exedy stage 2 clutch
exedy light weight flywheel
poly inserts
im so excited! ill post up dyno numbers after i break the clutch in properly
oh and my shaved CF trunk also
and this will yeild higher numbers then in my sig, since the numbers in my sig were only at 5,000 rpm since we didnt want to go crazy on the timing with out the meth
2.8 pulley
60's
poly inserts
so finally got my meth kit in lol lots of delays
i need to get the solinoid from them because we tapped it on my manifold and it is sucking the meth right out since its seeing so much pressure, that will be here tuesday and well re dyno with the correct timing
i have had the 2.8 and 60s for a while but since i havent gotten the clutch i want to wait till after that
the clutch is here but no flywheel, its getting made/shipped straight from exedy, theres like nobody that is stocking them for some reason
ill post up dyno numbers with the meth and stock timing, my sig numbers are only hp numbers till 5800 rpm so well see what we get with meth and a 7000 rpm pull
okay the meth kit is all done, solinoid went in wednesday
still waiting on the pressure plate to arrive from japan and the clutch can go in, then when thats broken in we can put the 2.8/60s/ported tb on
boosted 2.4s FTW
Lookin forward to results!
Get the poly inserts in yet? I have a set of prothane tranny bushings sitting here but have been reluctant to install due to common ridiculous vibes and car being a dd.
clutch is in! and its a monster compared to the stocker!
the vibes arent as bad as people make them out too seem
2.8 and 60s are going on this week once its broken in, as well as ls2 edit for tuning, hoping for 275whp
ordered this today
1xMid length header and downpipe combo
Car:Manual
Model:1 3/4 inch high temp paint
Option 1:w/o cat
Option 2:Mild steel downpipe
Option 3:2.5 inch downpipe, bolt in
Option 4:None selected
Option 5:Prepaid label for cat credit
Car:Manual
Option 1:w/o cat
Sl0wbaltSS
Nov 21, 2018 11:11 PM
