rough idle
Old Feb 19, 2012 | 10:43 AM
konartis91's Avatar
rough idle
my car started idling high and going up and down a little bit anybody have any ideas
Old Feb 19, 2012 | 10:57 AM
Mindrot's Avatar
I suggest you post more info about your issue. Could be a dirty MAF... *shrugs*
Old Feb 19, 2012 | 11:19 AM
konartis91's Avatar
when im at a light or in park the car will idle around 1100 and when its cold it will go between 1000 and 1300
Old Feb 19, 2012 | 03:05 PM
konartis91's Avatar
also i was driving down a horribly dusty road for an hour or so
Old Feb 28, 2012 | 09:24 PM
Finsternis's Avatar
If your defroster is on, that could be from the AC compressor turning on.
Old Feb 29, 2012 | 12:20 AM
noorj's Avatar
seems pretty normal to me, the car raises idle until its warm
Old Mar 3, 2012 | 06:16 PM
06cobaltss2.4's Avatar
Could be dirty throttle body, dirty MAF sensor. NOTE: only use MAF sensor cleaner to clean the MAF sensor otherwise you may as well just buy a new one.
Old Mar 3, 2012 | 06:24 PM
nhanson's Avatar
Check MAF and check for vacuum leaks
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Sep 28, 2015 02:46 PM
