scratching sound
Old Sep 19, 2007 | 06:55 PM
06sscobalt's Avatar
scratching sound
im gettin a really annoying sound from my brakes while driving without even touching the brakes at random times i get a sound like nails on a chalkboard coming from just the driver front brake when i press the brak it gets louder but the more i press in the brake after a certan point it will stop and when i release the break somtimes the noise will continue and somtimes it will stop. i was thinking maybe somthing is rubbing the rotor? i dont really know whats goin on any one have any ideas or suggestions?
Old Sep 19, 2007 | 07:00 PM
Woodyr007's Avatar
How many miles on the brakes?
Old Sep 19, 2007 | 07:02 PM
06sscobalt's Avatar
id say about 10k iv had the rotors replaced at the dealer once already and i had 10k on the car i now have 19700
Old Sep 19, 2007 | 07:12 PM
Woodyr007's Avatar
Hmm sounds like your pads might be bad, but I dunno pretty easy to check them, anywhere does free brake inspections
Old Sep 19, 2007 | 08:12 PM
Illini_06SS's Avatar
It could be a wheel bearing gone bad or a really bad brake job that has worn down the pad already and is set too close. I've heard a similar thing on Pontiac GPs.
Old Sep 20, 2007 | 10:22 AM
LewiSS's Avatar
There's a tab that contacts the rotor and makes the nails on chalkboard sound when the pads wear down. This is a wear indicator and is there to annoy you into changing your pads before the backing metal hits the rotor and you have to replace the rotor too. Check your pads for wear, and see if the little tab is real close to (or touching) the rotor. It might just be time for pads in spite of the low mileage.
Old Sep 21, 2007 | 02:38 AM
06sscobalt's Avatar
thanks man i went and baught some cheap pads from autozone ( gona get good pads and new rotors soon) and ill be changing them tomarrow so hopfully it takes care of the problem cuz it is annoying as hell.
Old Sep 23, 2007 | 07:53 PM
Apcsox's Avatar
ewwww, valucra(p)ft
Old Sep 23, 2007 | 07:57 PM
silentd's Avatar
make sure you sand and clean the caliper around where the pads sit. also use the grease they give you. this will prevent any noise
that may be what is wrong with your pads now, vibrating metal against metal. if you forget that it will make noise even if you have new rotors and pads
Old Sep 23, 2007 | 08:29 PM
06sscobalt's Avatar
i changed the pads and the noise is gone i compared the old ones to a new one and the old ones were worn down BAD there was almost nothing left of it new pads r workin good.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
